Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 19 of 39 <123 ... 181920 ... 373839>
Ianh
From what I can see all they have done is broaden the range of vin numbers associated with 110 & 130’s that they would fit brackets to.
Surely the EU notice requires more than the fitting of the brackets that don’t rectify the key issue of the axle end snapping off as even with the brackets fitted significant loss of control will result. Posing a real and ongoing danger of injury or death to occupants, other road users and other members of the public.
Post #974229 11th Dec 2022 12:41pm
spudfan
Ireland
I thought the latest recall with the brackets was a stop gap until they got a final full blown recall and axle replacement in place. Seems I was wrong. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #974241 11th Dec 2022 2:29pm
markb110
To save money and not cure the problem JLR will follow the proven method of stopping the Discovery 4 crank shaft snapping, change the ECU setting to reduce the pull away performance.
So expect to get your Puma's top speed reduced to 30 mph and a complimentary voucher giving you £50 off the purchase of a new vehicle....
I hope that i am jesting..... Rolling Eyes
Post #974246 11th Dec 2022 3:52pm
spudfan
Ireland
Many a true word spoken in jest..... Whistle 1982 88" 2.25 diesel
Post #974247 11th Dec 2022 3:59pm
Fredthechippy
Hi all - have there been any developments over the last few months. My 2011 110 with previously fitted magic brackets has cracked and started leaking. Trying to decide whether to tackle the JLR Goliath or bite the bullet and just get a new/old axle case.
Post #982696 16th Feb 2023 9:21pm
Fredthechippy
Post #982697 16th Feb 2023 9:21pm
spudfan
Ireland
Nothing has changed so far. I got in touch with various regulatory bodies here (3 in fact). Two contacted Land Rover who informed them that there was no recall notice for my vehicle. It is 2011 and had a recall for the magic brackets to be figured. Could be sometime yet before they admit anything. 1982 88" 2.25 diesel
Post #982710 16th Feb 2023 10:01pm
pat_eg
Australia
Hi Fred, I'd definitely try. I got a reasonable discount on a new case from hassling landrover Australia. I received some really ignorant replies from Landrover Australia before they came to the party. They know they are in the wrong. It's only a matter of time before a class action or something similar gains traction. I just couldn't wait. I ended up paying just over half my original quote for a new casing and fitment so it's worth persisting with.
Post #982772 17th Feb 2023 12:54pm
pat_eg
Australia
Post #982773 17th Feb 2023 12:58pm
itsdashy
United Kingdom 2012 Defender 90 Puma 2.2 PU Orkney Grey
Got my N706 recall this morning. I haven't had a look but what's the deal if there's already an oil leak present?
Post #1008343 21st Sep 2023 11:22am
spudfan
Ireland
Interesting point. Wonder what the procedure is if there are signs that things are amiss? 1982 88" 2.25 diesel
Post #1008344 21st Sep 2023 11:25am
ickle
With a potential crack in the weld - I wouldn't be driving it for a start.....
If it failed & caused damage / injury or death and it was proved you knew there was a problem, the onus would be on you not JLR for operating a defective vehicle.
I hate to think of the potential legal costs of that case!
HTH Keith
Post #1008345 21st Sep 2023 11:33am
itsdashy
As stated, I haven't had a look and would rather keep that cat in it's box. As this is an official safety recall I believe my opinion is less than worthless, the onus is on whoever services and looks after it. i.e. JLR or a professional independent.
What I'd like to know is, has anyone taken their vehicle in and been told their axle is already in failure? As this is a safety recall I'd assume the procedure would be on JLR to replace the failed part, especially considering it only has 60k on it.
Prepare for the worst, hope for the best etc.
Post #1008357 21st Sep 2023 1:22pm
I believe that if it has already cracked you'll get a new axle case.
A more interesting question to my mind is what happens if you've had the brackets fitted and then it cracks, do you get a new axle free of charge?
Post #1008392 21st Sep 2023 7:47pm
keith
Got my recall today. 2012 110
Post #1008443 22nd Sep 2023 9:49am
