![]() | Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case |
| spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812
Anyone who has got a puncture in a front wheel while driving will know how difficult it can be to keep control of the vehicle. This axle scenario is infinitely worse than that. 1982 88" 2.25 diesel
What did it say in the letter? 1982 88" 2.25 diesel
| stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561
Click image to enlarge 👍 |
So just to fit brackets and put the onus on you to keep an eye out for oil leaks. Why do they call it a "Range Rover Defender"? Only "certain" 2011/2012 year models. That's optimism for you. Mine is 2011 and I had the brackets fitted some years ago. I must check up when. 1982 88" 2.25 diesel
| Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736
I am afraid this is typical JLR.
A friend has a Range Rover Sport. There is an issue with bolts on the steering rack, which can fail. This is a well known problem. The car was almost unsteerable when his failed. JLR will only replace under recall on failure. I would question why anybody would purchase a new car from an organisation which will not accept responsibility for its faults, which are so serious as to put lives at risk. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915
As far as I recall that is exactly the same letter as before, containing the same piffle, platitudes, and misleading untruths.
The third paragraph is one which should live in infamy. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8365
yep same letter, have a few of them here over the years! Cheers
| DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1490
STILL NO MENTION OF DEFENDER 90'S THAT HAVE THE SAME AXLE !!!
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6346
reading that letter I do wonder if we've blown this out of all proportion? a failure appears only to have a marginal impact on steering direction etc. |
reading that letter I do wonder if we've blown this out of all proportion? a failure appears only to have a marginal impact on steering direction etc. the cheek of it. |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597
I wonder if JLR used the Range Rover name so as not to blemish the new Defender name. But they forgot to change the title. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 232
I know that the original Defenders have always been known for their vague steering feel but when the manufacturer claims that if the front hub comes away from the vehicle, then "it is possible that the steering may be less precise" you have to wonder what's on the menu in the staff canteen.
| PeeWee Member Since: 13 Apr 2017 Location: Somersetty Posts: 19
"Staff canteen"? that was probably flogged off years ago.
However, I suspect that the letter was written by the cheapest form of human life in the admin department - perhaps a YTS who has yet to hold a provisional moped licence? |
Here is how you do a recall
https://www.msn.com/en-ie/cars/news/subaru...c04d54306d 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
