Page 1344 of 1392 <123 ... 134313441345 ... 139013911392>
Geobloke - Great photo ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #974077 9th Dec 2022 5:49pm
geobloke
spudfan wrote:
A nice surprise,,,,
Too right... Snow... In Snowdonia... Rolling with laughter That almost never happens anymore...
Cheers Thumbs Up
Post #974080 9th Dec 2022 6:09pm
spudfan
Ireland
Not me but my daughter. She was out attending to her pony before she headed off the work placement in a hospital. She said she was unable to close the door on the 90 300 tdi as it froze stuck when she did! She closed it while driving.
 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #974095 9th Dec 2022 8:04pm
Mini Landie
United Kingdom 2003 Defender 90 Td5 HT Belize Green
Finally, after years of lusting and money going towards repairs, I finally purchased the Safari Equip rear receiver from 4x4Overlander. Received (hehe) it earlier this week and just got back in from trying to fit it. Well, I didn’t quite get that far.
As past experiences have been painful with regards to struggling to take something off, struggling to get something on, giving up and putting the original thing back on, I thought I’d be a bit smarter this time and make sure I can undo every nut & bolt - just a bit - before going the whole hog and taking everything off.
I’m glad I took that approach as I’ve managed to properly round off the head of the nut/bolt of a lashing eye. Awkwardly it’s the one that sits almost flush against the fuel tank so I can’t fit a bolt remover socket on it. Not unless I take off the fuel tank anyway… no thank you.
Looks like it’ll be going into a garage to do the job as I don’t have any power tools. Crying or Very sad
I took these photos before I got the idea to try some locking pliers, which just made it worse and is basically just completely round now. Balls…
 2003 90 TD5 Hardtop
Post #974163 10th Dec 2022 4:45pm
nitram17
15-50 quid for an angle grinder..........save you money on garage fees!
https://www.amazon.co.uk/Grinder-CHANTPOWE...&psc=1
an open wallet and an angle grinder and a big big hammer are the holy trinity of tools for defender ownership!
Post #974164 10th Dec 2022 5:00pm
Mini Landie
Problem is I think the angle grinder is a no-go due to it being such a tight space in there.
The Def is going into a garage near the end of the year anyway so may have to ask them to use their expertise to get the Censored out and just fit the kit for me (in case there are any other mother hubbards waiting in the wings!). 2003 90 TD5 Hardtop
Post #974173 10th Dec 2022 5:49pm
You could possibly try a nut splitter? That way you may save the bolt and avoid dropping the tank. Darren
Post #974189 10th Dec 2022 7:21pm
Mini Landie
Ooh a nut splitter may be a winner. I forgot those existed. I shall do some hunting... ta! 2003 90 TD5 Hardtop
Post #974190 10th Dec 2022 7:27pm
nitram17
Nut splitter might work! Could you not just move the exhaust to one side to make room for a power tool
anyway good luck
Post #974389 12th Dec 2022 2:32pm
Reciprocating saw for that with metal blade, also less sparks. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #974447 12th Dec 2022 6:27pm
kenzle8a
Moving one of my wife’s friends horses between yards in some arctic conditions, 1st time I’ve used low range in the yard.
Post #974577 13th Dec 2022 7:01pm
Mini Landie
So I was researching more about the installation of this Safari Equip 2” receiver. Most pictures I found were for installing onto a 110, but I have a 90, which comes with different cross member > chassis attachments. Anyway, I finally found a photo from 2013 that showed me exactly where I needed to mount the attachments… turns out I didn’t need to remove the lashing points after all as the chassis side mounts further down. 😬
So I’m continuing on with it. I’ve already snapped a head, so that’s fun. I’m now stuck on removing these two top bolts. I’ve undone them but is there a nut behind that I’m supposed to grab onto with a spanner or socket? Because I see no way of getting in there. I could just be being thick though, and not seeing the obvious.
 2003 90 TD5 Hardtop
Post #974746 15th Dec 2022 12:51pm
Mini Landie wrote:
... I’ve undone them ...
I am rather assuming that you haven't undone them or you wouldn't be asking the question!
TD5 and TDCi Defenders have threaded inserts in the rear cross-member for these setscrews and as a result if they are spinning, then I'm afraid you have a problem. The usual solution is to cut them off, then open up the rear crossmember and weld in good new material with captive nuts or new threaded inserts. There is very little else you can do.
Remember also that these are rather significant parts of your towing attachment and having found out that you have a corrosion issue inside the cross-member I would give serious thought before towing anything before it is resolved.
There was a thread on the forum, I think within the last year, where someone had this problem and cut open and repaired these fasteners.
Post #974750 15th Dec 2022 1:31pm
Mini Landie
Yeah, sorry, I can see how that was a bit misleading!
Well isn’t that just pants. I’ve been all excited about getting this piece of equipment, that it’s a kick in the corroded nuts when a setback like this happens.
I guess I’ll put everything back together to keep things from banging about and speak to my usual Landy specialist.
Thank you for your input. It is much appreciated, albeit a bit of a downer.
I’ll try to locate that thread you mentioned. 2003 90 TD5 Hardtop
Post #974752 15th Dec 2022 1:41pm
Yes, and I'm sorry to be the bearer of bad news. The earlier chassis which had though-bolts were more satisfactory, but the fuel tank precluded that approach on the later ones. Your receiver hitch will also use the bolt-holes (again with threaded inserts) that go upwards into the cross-member, so the upside is that these can be made good at the same time.
it's not a hard job for someone wit the welding skills, and your Defender will be better and stronger afterwards, but it is still a real bummer when you want the gratification of fitting your cool new accessory. You have my sympathy, welcome to the world of Defender-ownership!
Post #974757 15th Dec 2022 2:42pm
