Home > My Defender > Baltic blue 110usw
Page 12 of 15 <123 ... 1112 131415>
Siwynne
Gave up on rebuilding the turbo and ordered a cartridge today. It was too damaged with loose variable vanes.
Started reading about reinstalling the timing chain cover and nearly dropped a Censored when I found out it should be done with a positioning tool and they are about £120. For a turned lump of metal.
I’ve measured the end of the crank and measured the cover and will make one on the lathe for the total cost of £0
Aiming to get it back in at the weekend but tonight’s session outside was hardcore with the cold
Post #973871 7th Dec 2022 11:56pm
Screbble
Good luck -it sounds like you are making good progress and it will be better than factory when it’s done, and you’ll know every inch.
It’s a pain that the weather is not on your side - but it’ll warm up shortly👍
Post #973883 8th Dec 2022 9:47am
Siwynne wrote:
Started reading about reinstalling the timing chain cover and nearly dropped a Censored when I found out it should be done with a positioning tool and they are about £120. ...
That's a bit excessive considering that the proper genuine tool from Bosch is £19.07 +VAT etc. Shocked
Post #973893 8th Dec 2022 10:55am
Siwynne
It is excessive
£20 is more like it
I’ll still make one later to save waiting on delivery
Post #973911 8th Dec 2022 1:10pm
Siwynne
It’s back in and all connected bar one connector. I can’t for the life of me find where it goes to. It’s from the engine loom at the back by the ecu but I can’t find the connection for it. I am sure the collective knowledge on here will know
Post #975055 18th Dec 2022 1:58pm
Siwynne
I’m thinking I’ve got it on the wrong side of the engine. It seems dusty not oily so I’m thinking it goes along the top of the gearbox somewhere. I can’t find any reference to it online but am probably looking in the wrong place. It’s this oil and water then finished.
Post #975073 18th Dec 2022 7:46pm
Martin
Site Admin
Along the tunnel near the gearbox you will find its partner Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #975078 18th Dec 2022 10:38pm
Siwynne
Thank you thank you thank you
Near or offside?
I’ve been out there on my back in the rain for two hours. I thought it was down there but can’t find it.
It’s not the best spot to refit an engine in the weather we have had
Post #975079 18th Dec 2022 10:43pm
Martin
Site Admin
Nearside https://www.lrworkshop.com/connectors/defender-2012-2.2tdci/C0448  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #975081 18th Dec 2022 10:47pm
Siwynne
Once again thank you Martin. Found it and connected it.
Filled with oil and coolant. Need to run it up to get the final coolant fill. Battery on charge for an attempt at starting tomorrow. Fingers crossed the epic effort in freezing weather has been worth it
Post #975085 18th Dec 2022 11:44pm
Siwynne
It’s running.
Got a p0100 code to start with but that was only a shonky cable above the connector. I’ve cut it off and arranged it so it works and will order a new connector.
Small oil leak by filter housing to investigate and good to go
Post #975244 20th Dec 2022 2:18pm
Martin
Site Admin
If you need a MAF connector let me know  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #975256 20th Dec 2022 3:18pm
Siwynne
Thanks Martin. Already ordered as I didn’t realise you supplied these.
Post #975269 20th Dec 2022 5:23pm
Dinnu
Good job, and good to hear that the 2.2 is running again. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #975311 20th Dec 2022 11:04pm
Siwynne
Wonky vid but at least you get the idea https://youtube.com/shorts/fkrDvQYpXRI?feature=share
Post #975316 20th Dec 2022 11:28pm
