![]() | Home > Technical > Light switch and relay |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18034 ![]() ![]() ![]() |
The relay is present to switch the headlights off when the ignition is switched off, it doesn't prevent the full headlight current from passing through the switch.
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 601 ![]() ![]() ![]() |
Thanks blackwolf, that's very clear!
![]() -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1363 ![]() ![]() ![]() |
The lights will also be brighter because the relay and power source are all close to the headlight reducing the voltage drop over the wires. The grounds is local, but if you need to extend the power cable make sure you use heavy gauge
Yeah, good point, I expect the fitting on the series 3 to be a tad more challenging... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
