Home > Technical > Light switch and relay
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
There is something I am not quite sure about the wiring of the headlamps on the Defender (and on the Series as well).
To protect the light switch from deteriorating and eventually melting, and also increase the brightness of the headlamps, I added a separate loom with a relay (a Boomslang), something I did years ago on my Puma Defender, and that I am now planning to do on my Series 3 as well.
I vaguely remember that the reason was that the light switch was not protected by a relay. But looking at the electric diagram, it appears there is already a relay for the headlamps:
So now I am confused as to why a separate dedicated loom such as the Boomslang would make any difference for the switch and the brightness of the headlamps…
Can someone enlighten me? Wink “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #973227 2nd Dec 2022 5:37pm
The relay is present to switch the headlights off when the ignition is switched off, it doesn't prevent the full headlight current from passing through the switch.
Post #973229 2nd Dec 2022 5:43pm
o4dn
Thanks blackwolf, that's very clear! Thumbs Up “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #973231 2nd Dec 2022 5:53pm
TexasRover
The lights will also be brighter because the relay and power source are all close to the headlight reducing the voltage drop over the wires. The grounds is local, but if you need to extend the power cable make sure you use heavy gauge
Post #973242 2nd Dec 2022 7:41pm
o4dn
Yeah, good point, I expect the fitting on the series 3 to be a tad more challenging... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
Post #973250 2nd Dec 2022 8:29pm
