Home > Puma (Tdci) > B Pillar advice.
Polarismd
B Pillar advice.
Hi Landy Experts,
I recently had the hinges changed on my Puma. Is this right (see images) surely the bolt for the hinges shouldn't be poking into the vehicle like this. I know the Landrover isn't exactly safe but this looks awful.
I can cut the bolt down for my own satisfaction but does the trim really stop there?
Is there an aftermarket solution that makes it look better/safer? And what are the two bolt holes above and below? it looks like there should be a plate covering it?
Any ideas/comments would be greatly appreciated.
Regards
Chris
Post #972913 30th Nov 2022 10:35am
The bolt doesn't look right - it shouldn't project like that - but yes, the trim does stop there. Darren
Post #972918 30th Nov 2022 11:23am
The bolt is far too long, it should not extend out of the pillar. The trim does stop there and there is a hole with the bolt-ends visible, I found the a huge draft came out of mine so I covered them (neatly) with black duct tape to stop the gale.
Post #972920 30th Nov 2022 11:41am
BrickBox
If you’ve bought a hinge kit. That bolt should be for the lower hinge.
You should match up the new bolts with the old ones. You’ll see the difference then between top and bottom hinge. 2008 2.4 110 Utility Station Wagon XS.
Post #972923 30th Nov 2022 12:28pm
Polarismd
Hi,
Bloody hell, yes that makes sense.
I will take them out one at a time and check.
They are supposed to be a Landy expert as well!
Chris
Post #972924 30th Nov 2022 12:30pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
CSI does some plugs to cover these holes in the B pillar
http://www.csiparts.co.uk/en-gb/products/b...110/120732
I don't have them though, so cannot comment further.
/Mat
Post #972927 30th Nov 2022 12:43pm
Damn, I'd forgotten about them, which is made worse by the fact that I bought a set a few years ago and haven't fitted them Rolling Eyes Darren
Post #972928 30th Nov 2022 12:47pm
Polarismd
Just above and below the hole are two M10 fixings.
I wonder what LR had them installed for? I am thinking of getting a plate made and using some plastic bolts?
I think they must have thought of covering the hole and never got around to it?
Post #972930 30th Nov 2022 1:02pm
