Home > Puma (Tdci) > Dual mass flywheel reliability
RichardS
Canada 2009 Defender 110 Puma 2.4 CSW Alaska White
Are dual mass flywheels installed in 2.4TDCI powered Defenders prone to early failure? If I need to replace one is it possible to install a non dual mass as an alternative? My 36000mile (gently used) Defender, without warning, let out a harsh clunking sound and stopped with no "check engine" dashboard warning. It cranks but no start and heavy clunking sound. Previous experience with dual mass BMW flywheel very poor and expensive and exhibited similar failure symptom.
Post #971379 16th Nov 2022 10:11pm
Yes, SMF standard on the 2.4 or at least this is my understanding + more reliable too and cheaper to replace and they are not cheap even SMF’s. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #971382 16th Nov 2022 10:15pm
BrickBox
Single Mass on the Puma 2008 2.4 110 Utility Station Wagon XS.
Post #971385 16th Nov 2022 10:23pm
Grenadier
Re: Dual mass flywheel reliability
Sure it’s not the starter motor? They can seize up. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #971421 17th Nov 2022 12:00pm
Cranking, clunking and not starting doesn't sound like a flywheel fault to me, nor a starter fault. It is possible that a clutch has destroyed the crankshaft position sensor, but I'd be more inclined to think that it is a broken timing chain or something along those lines.
You can certainly rule out DMF failure, because as commented above it doesn't have one,.
Post #971478 17th Nov 2022 7:10pm
