![]() | Home > Puma (Tdci) > Dual mass flywheel reliability |
RichardS Member Since: 29 Apr 2020 Location: Toronto Posts: 7 ![]() ![]() ![]() |
Are dual mass flywheels installed in 2.4TDCI powered Defenders prone to early failure? If I need to replace one is it possible to install a non dual mass as an alternative? My 36000mile (gently used) Defender, without warning, let out a harsh clunking sound and stopped with no "check engine" dashboard warning. It cranks but no start and heavy clunking sound. Previous experience with dual mass BMW flywheel very poor and expensive and exhibited similar failure symptom.
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1005 ![]() ![]() ![]() |
Single Mass on the Puma 2008 2.4 110 Utility Station Wagon XS.
Sure it’s not the starter motor? They can seize up. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17871 ![]() ![]() ![]() |
Cranking, clunking and not starting doesn't sound like a flywheel fault to me, nor a starter fault. It is possible that a clutch has destroyed the crankshaft position sensor, but I'd be more inclined to think that it is a broken timing chain or something along those lines.
You can certainly rule out DMF failure, because as commented above it doesn't have one,. |
