Home > Technical > Headlamp switch
22900013A
Headlamp switch
My headlamp switch is burning out *again*. This is the second if not third genuine one that's been fitted. It now cuts out entirely if I go over bumps, if I push and hold the switch they stay on.
Is there any aftermarket solution that doesn't fail every couple of years, as obviously headlights randomly cutting out in winter is a bit of an issue... 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #970202 7th Nov 2022 8:13am
Your only long-lasting solution is to rewire the headlights so that the switch operates relays and the relays operate the lights. Your headlights will be brighter and you'll have no more switch failures.
There are off-the-shelf looms for this if you like spending money (many threads on here on these) or if hit by the cost of living you can make your own for a fraction of the cost.
Post #970203 7th Nov 2022 8:36am
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
A replacement headlamp loom with relays so that the switch doesn't take the full current draw seems to be the usual solution, available from such as Landreiziger.
I've wondered about replacing things at the switch end instead, but not seen a commercial offering for that.
Post #970204 7th Nov 2022 8:36am
Martin
Site Admin
Other option is the LR parts to add the relay to reduce the load on the main lighting switch:
https://www.defender2.net/gallery/albums/u...0relay.pdf
Or a clone of that kit.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #970211 7th Nov 2022 9:42am
swt
Thank you, Martin! In years of following threads on overloaded headlamp switches (and replacing a couple), I've somehow never noticed that option, which seems so much simpler.
I suppose that it doesn't give the advantage of reducing voltage drop to the headlamps, so there's still a place in the world for new looms, for folks who not unreasonably want brighter headlamps.
Post #970212 7th Nov 2022 9:59am
