Home > Puma (Tdci) > Positive battery terminal issues
Thug
South Africa 2009 Defender 90 Puma 2.4 CSW Indus Silver
I've just recently picked up a couple of Optima batteries (RT starter & YT auxillary) together with a Gwyn Lewis battery tray.
As I measuring everything out this morning and seeing what the best orientation is, I noticed that as per the picture, the terminal connected to the mega fuse is a couple of cm too short to fit onto the RT terminal.
Is there a longer positive terminal available, or, failing that, are there any suggestions as to the best manner in which to connect the terminal/cable?
Post #970003 5th Nov 2022 10:42am
Is there enough clearance to turn it upside down? Failing that, you could fit a standard terminal to your cable and mount a replacement mega fuse remotely. Darren
Post #970004 5th Nov 2022 10:49am
Thug
No, there isn't enough room to invert the connector.
I was thinking that if I cut off the connector along the yellow line, I could then get a normal terminal and connect to each other with a small section of 50mm cable.
Post #970007 5th Nov 2022 11:05am
Thug
I see that there is a thread on the same issue here.
https://www.defender2.net/forum/post861572.html
Post #970009 5th Nov 2022 11:09am
The megafuse is a recent addition (introduced with the Puma) and I suspect was only fitted for type approval or regulatory reasons. Its sole purpose, as far as I am aware, is to lessen very slightly the risk of fire in the event that you have a hard frontal collision which causes the starter (and possibly alternator, I can't recall offhand if this is also connected via the MF, I think not) cabling to short to ground.
It is however highly likely that cable damage could occur which turns your vehicle into a fireball long before the MF blows and personally I think the MF is of very questionable benefit. If you are seriously worried about fireballs, fit a manual isolator (and do your best to remain conscious and cable during a serious accident). You could combine an isolator with an inertia switch if you are really worried.
Remember that deleting the MF makes you no less safe than you would be in an earlier Defender anyway.
Post #970013 5th Nov 2022 11:33am
LR Nuts
Thug - this is the time, when Land Rover turns every driver into an engineer.
I would build an 'extension post and cap', solved without changing any standard part.
Post #970014 5th Nov 2022 11:36am
Thug
Thanks guys.
Post #970019 5th Nov 2022 12:40pm
SteveG
2005 Defender 90 Td5 CSW Belize Green
I personally would fit a manual isolator switch to the front of your seat box. You could then remove the mega fuse and connect your cable to switch and insert new 50 mm tail to switch from battery. That way you can easily isolate power to vehicle that’s within easy reach of the driver seat.
Post #970050 5th Nov 2022 5:40pm
Thug
Thanks, that’s a good idea.
Post #970055 5th Nov 2022 6:12pm
Dinnu
Something like this to offset the terminal, but current rating looks a bit low.
https://www.amazon.com/dp/B0B8J1F73B/ref=s...9kZXRhaWwy 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #970058 5th Nov 2022 6:46pm
Thug
I’ll look at a Victron Battery Switch.
Has a continuous rating of 275A, one minute at 450A and a cranking rating at 1200A.
https://www.victronenergy.com/battery-isol...tch-on-off
Post #970064 5th Nov 2022 7:23pm
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
Just take the megafuse out of the holder down the side, reterminate and put it in a new holder, coupled with a short link lead. I've done this with my batteries. If you need more info just let me know. North Cumbria Search and Rescue - Team Leader
Post #970066 5th Nov 2022 7:37pm
Thug
Thanks all for the different suggestions.
Post #970090 6th Nov 2022 8:05am
