![]() | Home > Puma (Tdci) > Positive battery terminal issues |
Is there enough clearance to turn it upside down? Failing that, you could fit a standard terminal to your cable and mount a replacement mega fuse remotely. Darren
Thug Member Since: 02 Aug 2022 Location: Johannesburg Posts: 20 ![]() ![]() ![]() |
No, there isn't enough room to invert the connector.
I was thinking that if I cut off the connector along the yellow line, I could then get a normal terminal and connect to each other with a small section of 50mm cable. ![]() |
I see that there is a thread on the same issue here.
https://www.defender2.net/forum/post861572.html |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17850 ![]() ![]() ![]() |
The megafuse is a recent addition (introduced with the Puma) and I suspect was only fitted for type approval or regulatory reasons. Its sole purpose, as far as I am aware, is to lessen very slightly the risk of fire in the event that you have a hard frontal collision which causes the starter (and possibly alternator, I can't recall offhand if this is also connected via the MF, I think not) cabling to short to ground.
It is however highly likely that cable damage could occur which turns your vehicle into a fireball long before the MF blows and personally I think the MF is of very questionable benefit. If you are seriously worried about fireballs, fit a manual isolator (and do your best to remain conscious and cable during a serious accident). You could combine an isolator with an inertia switch if you are really worried. Remember that deleting the MF makes you no less safe than you would be in an earlier Defender anyway. |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1274 ![]() ![]() |
Thug - this is the time, when Land Rover turns every driver into an engineer.
I would build an 'extension post and cap', solved without changing any standard part. |
Thanks guys.
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 671 ![]() ![]() |
I personally would fit a manual isolator switch to the front of your seat box. You could then remove the mega fuse and connect your cable to switch and insert new 50 mm tail to switch from battery. That way you can easily isolate power to vehicle that’s within easy reach of the driver seat.
Cheers |
Thanks, that’s a good idea.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3584 ![]() ![]() ![]() |
Something like this to offset the terminal, but current rating looks a bit low.
https://www.amazon.com/dp/B0B8J1F73B/ref=s...9kZXRhaWwy 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
I’ll look at a Victron Battery Switch.
Has a continuous rating of 275A, one minute at 450A and a cranking rating at 1200A. https://www.victronenergy.com/battery-isol...tch-on-off |
DuncanS Member Since: 07 Dec 2013 Location: Cumbria Posts: 299 ![]() ![]() ![]() |
Just take the megafuse out of the holder down the side, reterminate and put it in a new holder, coupled with a short link lead. I've done this with my batteries. If you need more info just let me know. North Cumbria Search and Rescue - Team Leader
Thanks all for the different suggestions.
