![]() | Home > Puma (Tdci) > Puma 2012 Front Axle |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2547
Payney1000 , looks like the EU has issued a recall notice, instigated by France. Looks like you have made a significant difference
See link https://ec.europa.eu/safety-gate-alerts/sc...14?lang=en Highlighted by supacat in this topic https://www.defender2.net/forum/post968887.html#968887 |
| Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6347
where do we stand with regards to a trip to europe - would our vehicles be deemed illegal on the roads out there without the recall having taken place.
if so would it be reasonable to assume they're not fit for purpose? if they're fit by EU standards and we bought them when part of the EU ..... ???? glad there's a recall on the EU ones at least. and what will that be - an extra set of brackets? |
/\ most probably
| Payney1000 Member Since: 16 Feb 2022 Location: Brittany Posts: 24
Dear All, This is the start. Due to landrover still deny that they are at fault. I released the inspection report to the EU safety board. They inspected the vehicle and agreed it’s Landrover fault and they have known this for years. This safety re-call is an ordered re-call by the EU for Landrover to replace not brackets !!! All vehicles effected with new axles at thier cost. They have starting today to re-call all vehicles within 6 months of this notice. I’m the coming days re-call should start coming from other Eu country’s this also includes the DVSA branch will also order Landrover to replace the axles. It’s a win for the small people But if it stops someone being killed or injured that’s a win for me . My legal battle still goes on but iam also pleased this helps me massively. |
Outstanding Payney1000, truly outstanding .
Everyone impacted by this will benefit from your actions. I sincerely hope your legal battle results in the best possible outcome for you, and sets a precedent for others to be properly recompensed for any suffering they have endured due to this failure as well. |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18051
It will be interesting to see how this progresses. One point which hasn't been discussed in the light of the EU Recall directive but which was raised in Payney1000's earlier post (post 69 in this thread) is that the axle was unacceptably weak and inadequate for a 4x4 of any kind to pass EWVTA even when friction welded, the basic axle was flawed by design even before the weld problem emerged. This is supported by evidence reported on the forum where vehicles outside the LR recall have suffered weld failure and split casings.
This may explain the lengths LR has gone to to cover up and suppress the issue, but raises the possibility that all Defenders could be recalled irrespective of weld type and wheelbase. That really would hit the headlines. I wonder how long it will be before the people behind the annoying "Did you buy a diesel car ...." advertisements turn their attention to "did you buy a Land-Rover Defender manufactured between 1985 and 2016....."? |
| kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074
It's not a great thought that ones axle could come apart. I had a take off axle from a Puma 110 fitted to mine as a replacement. Its friction welded but like Blackwolf once I found out about this I put the brackets on as a safety measure.
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Wow, what a read...
For clarity, are you referring to just the Tata/Indian made axles, or does "flawed by design" mean axles made elsewhere before and after the Tata/Indian made axles? |
I was referring to Payney1000's post (number 69 in this thread, quoted below), in which he says that his insurance company assessed his failed front axle and concluded that it would not have passed EWVTA tests if the inadequacy of its design was revealed, specifically the fact that "... the casing molding was not up to vehicle spec for the weight and the vehicle being a 4x4. The report says the casing levels was less than legally needed for a small trailer."
It is possible that there were other changes when production was moved to India, however to the best of our (current) knowledge it was the method of assembly and not the materials thicknesses and specifications which changed. This suggests that none of the recent axles has been adequate, and I referred to the number of failures we have had reported on the forum from owners of vehicle outside the recall range which I feel tends to support this. I can't remember all of them, but there was a bent axle, a split axle, Noworries4x4 (the Ladybird Crane Hite 90), and several others with axle failures (which were not necessarily the welds failing and the ends breaking off) all of which occurred in normal use and which collectively build up a picture of inadequate axle strength. If you then factor in the number of Pumas which have had the front diff disintegrate (which includes mine) the picture is even worse. An understrength, poorly assembled casing containing a differential assembly which is not strong enough for the driveline. We also know that Land-Rover has known about this for a very long time and has chosen to do as little as possible about it. Pretty shameful really. Quoted below is Payney1000's post, number 69 in this thread:
Incidentally I propose that in recognition of his achievements in getting this problem recognised by the wider world and the regulatory authorities, Payney1000 should be official awarded "Forum Legend" status! |
I was rereading some of the earlier threads on this subject, and had forgotten that Grenadier had posted the letter he received from LR on the subject. Note that this is described as a "Voluntary Safety Related Recall" which is wonderfully ambiguous, does that mean that Landrover hasn't been forced to do it and is doing it voluntarily, or does it mean that owners are not required to pay any attention to it? I suspect the former, but it may explain why only one in every ten affected vehicles has been through the programme.
The other thing that will, I think, live in the "annals of understatement" forever is the third paragraph: "If the wheel hub assembly and the suspension collapse or detach from the vehicle, vehicle stability will be compromised and the degree of directional control compromised, this significantly increases the risk of an accident." If it wasn't so serious, and being treated in such and irresponsible and cavalier fashion by LR, it would be hilarious. The quote below is from this thread.
It is a little interesting to wonder what would actually happen if LR was ordered to replace the front axle in every old-style Defender it had made during the last 20 years of production, bearing in mid that it would presumably had to design a new stronger axle before then tackling a huge recall. I can't really see it happening. |
| DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1502
No production Defender axles were ever made in India. |
^^ Have you not read Payney1000's post (quoted in my post above), or are you disputing what the JLR engineer told him? Perhaps you know different?
Is there anyway of identifying the TATA made axles of the friction welded variety?
I think the India made axles are a red herring in the story. Everything else is pretty accurate.
| All times are GMT |
