Home > Puma (Tdci) > Unknown plug/sensor
vinny
Ireland 1987 Defender 90 Other PU Java Black
Unknown plug/sensor
Can anyone identify this plug sensor beneath the turbo on my 2007 2.4 tdci? It’s not connected to anything I’ve searched on microcat but can’t identify what it’s for or if it should be connected!
Post #802812 19th Nov 2019 3:34pm
Yes, it is there just to make you ask the third most popular question on the forum!
It actually serves no purpose on the Defender, but it is used on some of the other vehicles which use the same engine and is an oil level sensor. You will probably find that in addition to the sensor on the block there is a harness with a matching plug tied up out of the way (I couldn't see from the photos in your gallery), but they are not supposed to be connected on the Defender. I don't think anything bad actually happens if you do plug them up, but it certainly won't have any beneficial effect.
Post #802814 19th Nov 2019 4:02pm
vinny
Cool thanks for clarifying 👍 Next question , what oil should I put in the engine ...😆 Just kidding
I’ve the engine on the floor and have replaced the clutch, rear crank seal, vacuum pump, egr valve and currently replacing the injector seals and the seals where the injector pass thru the rocker cover. I’ve read the posts on the timing chain and how it’s not as robust as the td5. I’m leaning towards a kit with the sprockets and new cover. My question is are there brands to avoid or is there a generally accepted good supplier? paddocks and Craddock are expensive compared to transit parts uk
Post #802861 19th Nov 2019 8:06pm
MK
Sensor? located under the intake manifold
Any idea whats this plug? It is located under the intake manifold
 Puma 110" SW
Post #967801 16th Oct 2022 12:30am
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
possibly the EGR? Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #968017 17th Oct 2022 1:26pm
MK
I was told it is the throttle body. And it is a Twisted Evil pig to fit and remove Puma 110" SW
Post #968042 17th Oct 2022 3:54pm
There is no "throttle body" on a TDCi (nor TD5 for that matter).
Post #968051 17th Oct 2022 4:58pm
MK
Throttle then Puma 110" SW
Post #968052 17th Oct 2022 5:01pm
Martin
Site Admin
Yes there is, on a 2.2. Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #968060 17th Oct 2022 5:50pm
Ah, didn't know that, happy to be corrected! There isn't on a 2.4.
Post #968063 17th Oct 2022 6:07pm
