![]() | Home > Puma (Tdci) > LT230T info |
| giacomo.m Member Since: 06 May 2011 Location: Roma Posts: 19
Thank you 100inch
yes it was disassembled to decouple the gearbox from the engine, but how can I have it mounted turned 180 ° ? Giacomo |
| 100inch Member Since: 15 May 2012 Location: Brunswick Posts: 411
Ensure part 35/31 facing forward. You can actually mount them facing backwards on a TDCI. m |
| Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3649
35/31 are part of the diff lock mechanism.
The high/Low linkage is 25, albeit on a TDCI the terminals are plastic ball sockets, which I hear are prone to breaking. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
You are correct, however when mounted the wrong way it seems to press against the Hi/lo lever. m
Got me curious so I checked a picture I have from a friend's TDCI: Click image to enlarge And I also have a picture from mine, although not so clear which direction it is mounted: Click image to enlarge But in both cases, the diff lock linkage seems to be to the 'outside' of the diff lock pivot selector shaft, which would make more clearance for the Hi/Low lever (the clearance is visible towards the top edge in the 2nd photo above). Good point 100inch. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
| ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264
the issue is usually incorrect adjustment of the high/low rod, lever the red side clip out at the cab end,
using an adjustable spanner, clunk the transfer case lever forward to the front of the vehicle so you are in high, hold the lever in the cab in the high position, push the red clip in to clamp this position, Dave Dave |
this
Click image to enlarge Dave |
thanks ashtrans
i have already tried with the rod all in or all out, but the problem remains... Giacomo |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
The reason why there are differences occurred to me some time after I made the above post, but I thought was worth adding to this old thread for the benefit of anyone searching for informatin in the future. The Disco2 has a significantly larger diameter front output flange than any Defender, to mate with the double-cardan propshaft used on the Disco2. The change was therefore made to allow the larger flange to have adequate clearance by shortening substantially the forward protrusion of the selector shaft. |
