Home > Puma (Tdci) > LT230T info
Page 2 of 2 <12
100inch
Australia 2010 Defender 110 Puma 2.4 CSW Santorini Black
Was the Hi/L linkage recently removed from the TB? Cause you can actually fit it the wrong way (by 180deg). It will work but not properly engage. m
Post #967387 12th Oct 2022 5:31am
giacomo.m
Italy
Thank you 100inch
yes it was disassembled to decouple the gearbox from the engine,
but how can I have it mounted turned 180 ° ?
Giacomo
Post #967460 12th Oct 2022 5:00pm
100inch
Ensure part 35/31 facing forward. You can actually mount them facing backwards on a TDCI. m
Post #967498 12th Oct 2022 10:26pm
Dinnu
35/31 are part of the diff lock mechanism.
The high/Low linkage is 25, albeit on a TDCI the terminals are plastic ball sockets, which I hear are prone to breaking. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967505 13th Oct 2022 5:26am
100inch
You are correct, however when mounted the wrong way it seems to press against the Hi/lo lever. m
Post #967506 13th Oct 2022 5:31am
Dinnu
Thumbs Up
Got me curious so I checked a picture I have from a friend's TDCI:
And I also have a picture from mine, although not so clear which direction it is mounted:
But in both cases, the diff lock linkage seems to be to the 'outside' of the diff lock pivot selector shaft, which would make more clearance for the Hi/Low lever (the clearance is visible towards the top edge in the 2nd photo above).
Good point 100inch. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967511 13th Oct 2022 6:11am
ashtrans
Site Sponsor
the issue is usually incorrect adjustment of the high/low rod, lever the red side clip out at the cab end,
using an adjustable spanner, clunk the transfer case lever forward to the front of the vehicle so you are in high, hold the lever in the cab in the high position, push the red clip in to clamp this position,
Dave Dave
Post #967656 14th Oct 2022 2:36pm
ashtrans
Site Sponsor
this
 Dave
Post #967657 14th Oct 2022 2:39pm
giacomo.m
Italy
thanks ashtrans
i have already tried with the rod all in or all out, but the problem remains...
Giacomo
Post #967762 15th Oct 2022 4:30pm
blackwolf wrote:
There are two implementations of the detent mechanism, I have no idea why. I do now, see below.
This is a TD5 box, with the detent ball and spring just behind the difflock switch.
This is a TDCi box, with the detent ball and plunger fitted from below acting on a forward extension of the selector shaft.
The reason why there are differences occurred to me some time after I made the above post, but I thought was worth adding to this old thread for the benefit of anyone searching for informatin in the future.
The Disco2 has a significantly larger diameter front output flange than any Defender, to mate with the double-cardan propshaft used on the Disco2. The change was therefore made to allow the larger flange to have adequate clearance by shortening substantially the forward protrusion of the selector shaft.
Post #1039431 8th Jul 2024 9:52am
Page 2 of 2 <12
