Home > Puma (Tdci) > Oil for differentials - Defender Puma.
hjellemorten
Norway 2007 Defender 90 Puma 2.4 HT Rimini Red
New Defender owner, and now changing the oil on both differentials, Puma. Ongoing, so quick feedback is appreciated:-).
Can CASTROL TRANSMAX AXLE LONG LIFE 75W-90 be used on both front and rear?
- https://www.castrol.com/en_gb/united-kingd...xle-75W-90
Noted that this? (non limited slip) :-0.
Post #967083 8th Oct 2022 3:19pm
Yes, it's fine for both. Darren
Post #967084 8th Oct 2022 3:29pm
Ianh
Post #967087 8th Oct 2022 3:53pm
hjellemorten
Thanks for guidance. Also, ran short, about 100-200ml of CASTROL TRANSMAX AXLE LONG LIFE 75W-90. Can I top up with CASTROL TRANSMAX UNIVERSAL LL 75W-90 ?
Post #967095 8th Oct 2022 5:34pm
Dinnu
Looking at the datasheets:
Transmax Axle Long Life 75W-90
Axle Fluid - Multivehicle
Description
Castrol Transmax Axle Long Life 75W-90, formulated with Smooth Drive TechnologyTM, is a full synthetic rear axle fluid.
It provides superior protection, especially when driving under stop-start or extreme conditions e.g. towing. This enables
smoother axle operation and noise reduction, resulting in a more comfortable drive throughout the lifetime of the vehicle.
Specially designed and approved by BMW for use in all BMW final drives fitted with conventional (non limited slip)
differentials. It is Castrol's prime recommendation for final drives in heavy commercial vehicles, and is approved by MAN,
Scania and ZF.
Transmax Universal LL 75W-90
Universal Fluid for manual transmissions and axles
Description
Castrol Transmax Universal LL 75W-90 formulated with Smooth Drive Technology™ is a full synthetic multi purpose
manual transmission and final drive lubricant. It may be used in synchronised manual transmissions and final drives /
differentials of a wide range of vehicles (commercial vehicle, construction equipment) where API GL-4 or API GL-5 fluids
are required and it carries a number of approvals
I guess the former is just more expensive because it is approved by BMW Shocked
Otherwise they are very similar oils and there will be no issue mixing them. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #967099 8th Oct 2022 5:47pm
hjellemorten
Thanks guys👍. Very much appreciated.
Post #967111 8th Oct 2022 8:14pm
bear100
I use Motul Gear 300 oil in diffs, transfer and gearbox a bit pricey but well worth the extra and simplifies only having 2 oils Very Happy 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #967113 8th Oct 2022 9:08pm
X4SKP
As above… Thumbs Up
(Opie Oils / Site Sponsor) SKIP
Post #967120 8th Oct 2022 9:37pm
