![]() | Home > Maintenance & Modifications > injector overhaul |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1995 ![]() ![]() ![]() |
Nobody knows
![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
puma2010 Member Since: 09 May 2012 Location: glos Posts: 28 ![]() ![]() ![]() |
Hello Bear,
Sorry I have just seen your post. I have done this job on my 2010 2.4 Defender twice now. You will need to buy new stretch bolts, and copper washers. I also did buy the small o rings and the bigger black o ring seals that fit into the rocker cover, I didnt need to replace the latter 2 items. I also took the injectors to a local spacialist for cleaning and setting/checking. Make sure the seats where the copper washers fit are very clean, and you work to the torque setting plus the 180 degree advance for the stretch bolts. Good luck. ![]() |
