![]() | Home > Td5 > transfer box revision |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8329 ![]() ![]() ![]() |
Another seal. Like the old one that c9mes out, depending how you rem9ve it. Cheers
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17868 ![]() ![]() ![]() |
The tool you want is 307-479 (previously numbered LRT-41-012) available from Bosch for £81.92 + postage + VAT if you have an account with them, or from Dingocroft for £145 + postage +VAT if you don't have an account with Bosch (which is actually a rather shocking mark-up by Dingocroft).
Alternatively you might feel that getting on for £200 is a bit much for a very simple tool, in which case you might want to check out this one on eBay, at a more realistic £15.35 including postage. I have both types, and although the genuine tool is better it is certainly not £150 better, and the eBay tool does the job nicely. |
doruk1981 Member Since: 15 Aug 2022 Location: Aargau Posts: 101 ![]() ![]() ![]() |
thanks a lot for the recommendations - I'll bully my local dealership if I can ask them to order one unit for me from Bosch . but given I'm in Switzerland, it might be cheaper to go with the dingocroft directly anyhow ... what just cringes my mind is that I'll be using this once and then it'll be taking space for the next 100k km in the toolbox Td5 110 Station
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
I have got some of the tools from this guy which have all been spot on:
https://www.ebay.co.uk/itm/295237692307?ha...SwjVResD~m Worth a go. Cheers 02' 110 TD5 Double Cab Rebuild Thread |
That's the same seller as the eBay link in my post above. For £12 his tool, which is a very close match to the genuine one and does just as good a job, is unbeatable value.
You can buy a second-hand LT230 for the price of the genuine tool! |
thanks a lot for the recommendation. just ordered the ebay equivalent version. lets see how it goes Td5 110 Station
Sorry missed the ebay link in your reply! I did send the guy my drawings for the LT230 input seal driver and the R380 input and output seal drivers so he might start producing those at some point too. I just 3D printed a set to use for my own rebuild. Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
would you mind to share the 3d models with us? that would come handy actually for personal use Td5 110 Station
