Home > Td5 > Trouble with Nanocom… help!
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
So here’s issue. Last week I used the Nanocom to power bleed drivers side after a brake rebuild. Yesterday did the left side and the ABS menu option has disappeared from my Nanocom screen. WTF?
I tried to upgrade the firmware and my PC recognizes the unit when I tap the “Kernal” icon on the Nanocom for the install but nothing happens, nothing loads on the PC to start the upgrade??? I tried the same on a second PC I have and same thing. Both PCs have old Windows OS like Vista…
Any ideas? 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #965575 20th Sep 2022 9:08pm
kenzle8a
Could it be the old os? I did my nanocoms firm ware last month using windows 10 on a VM on my MacBook pro
Post #965576 20th Sep 2022 9:23pm
4RF RDS
Yes that is why I listed that part in my post. I am going to try another more modern PC tomorrow. Still does not explain why the menu ABS disappeared though. I wish I could somehow just use my iPad…
Thanks for the thought. Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #965577 20th Sep 2022 9:27pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Try flashing the Nanocom with a different USB cable.
I've had a very similar issue with a broken USB cable here, flashing the Nanocom would fail or do nothing.
While at it, I'd also recommend to overwrite the configuration to start afresh, just make sure you have your codes at hand as you'll have to re-enter them. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #965618 21st Sep 2022 1:17pm
4RF RDS
Boo, Big Cry same thing. Thanks for the assist. I’ll try a newer computer later this week at a buddies place.
Cheer s 2020 range Rover Mk IV Autobiography PHEV
1967 MGB GT
Post #965659 21st Sep 2022 8:14pm
