![]() | Home > Td5 > Trouble with Nanocom… help! |
Could it be the old os? I did my nanocoms firm ware last month using windows 10 on a VM on my MacBook pro
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Yes that is why I listed that part in my post. I am going to try another more modern PC tomorrow. Still does not explain why the menu ABS disappeared though. I wish I could somehow just use my iPad…
Thanks for the thought. ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 588 ![]() ![]() ![]() |
Try flashing the Nanocom with a different USB cable.
I've had a very similar issue with a broken USB cable here, flashing the Nanocom would fail or do nothing. While at it, I'd also recommend to overwrite the configuration to start afresh, just make sure you have your codes at hand as you'll have to re-enter them. “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique. -- 2009 2.4 Puma Defender 90 SW 1979 Land Rover Series 3 88" |
Boo,
![]() Cheer s 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
