![]() | Home > Puma (Tdci) > Strange Smell |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303 ![]() ![]() ![]() |
I also occasionaly get a odd smell, sometimes a subtle "cooking" smell, but I put this down to a DPF clean and off-road muck burning on the exhaust system as it gets hot in places it does not normally due to shortish trips. Zaid-M
www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4813 ![]() ![]() |
It could be coolant getting burnt off a hot surface. Check the water pump for leaks or if there are streaks on the coolant reservoir coming from the cap this will be the source of the smell. 1982 88" 2.25 diesel
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20996 ![]() ![]() |
Most likely screenwash spillage due to being well filled up, the cap also has a breather in it.
As you use the screenwash it’ll stop. Always happens after filling screenwash bottle, replacing the cap may improve it a little. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
We had a strange smell that turned out to be a/c fluid. The engine lifting bracket, the red one at the back of the engine, had come loose and hit the a/c pipe below it resulting in a leak. New pipe cleared the problem. It is a long short to have that on your one but you never know. Peter
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17982 ![]() ![]() ![]() |
A few weeks ago I found I had a container of "Demon Tweaks" heavy duty screenwash left over from last winter, which I had bought when I was temporarily unable to get my usual brand. Perhaps foolishly I filled the reservoir with it (diluted in a manner appropriate to the summer, of course). It smells very strongly of bananas. Now every time I squirt the screen or headlights (yes, I am bragging ![]() I can't wait for it to run out. The only one I have ever encountered which was worse was a a container of Halfords "scented" screenwash some years ago, which made the car smell like a brothel (or like I image a brothel would smell, before anyone asks). That was worse than the bananas. What's wrong with screenwash that smells like screenwash? |
I use the 5L Rain x screenwash premix you can only get from Halfords. I’m happy with it. ____\We|Will|Win/___
