Home > Maintenance & Modifications > Clutch failure poll type comparison.
Page 1 of 3 123>
For curiosity, I thought it would be interesting to ask everyone what mileages the have achieved on each and every clutch they have had and what was at fault when you had a problem with it.
It’s widely known that nearly all of us with a 2.4 and 2.2 Puma has had at least one clutch replacement or multiple.
I’ll start the ball rolling…
40k (problem was slave, pinhole fluid leak plus springs became weak). Clutch and slave replaced, existing Flywheel okay as it was and output shaft fine just re greased and refitted).
Symptom was excessive slip, incredibly light clutch and delayed drive by a few seconds when into each gear.
88k (problem unknown yet, will update in due course *later edited it was a friction plate spring failure*).
(I predict possible, failed slave, spring fell out or pilot failure).
Symptoms are light clutch feel, when warmed up after approx 5 miles or so cannot get into gear.
Happens randomly, typically at pulling up to a junction and can’t then select 1st to pull away again.
When cold acts as normal, clutch fluid nearly emptied and black but no sign of obvious leaks.
Master cylinder replaced and re-bled but not solved the issue.
So;
clutch 1 40 k
Clutch 2 48k
Clutch 3:-
Both (1&2) were Genuine LR clutches and 2.4 slaves, next I’m having the Sachs Transit 4x4 version fitted and the 2.2 slave, valve and adaptor. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #964686 11th Sep 2022 10:55pm
Siwynne
2013 110 USW
1 38k replaced when output shaft was replaced dealer said slave was in a poor state
2 pending as per recent thread at 121k
Post #964694 12th Sep 2022 6:56am
discomog
Watching this thread as it will be interesting to see how many clutches are replaced due to outside influences ie caused by leaking slave cylinders or replaced as a consequence of a failed spigot shaft. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #964699 12th Sep 2022 8:11am
jst
32k clutch springs rattling, cover plate, friction plate and slave changed
93k still going (touching wood) Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #964719 12th Sep 2022 9:43am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Also watching with interest. Only 30k mls, so far no problems.
Could you add model year?
Post #964756 12th Sep 2022 3:59pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
1st clutch change August this year: 2007 90SW, 80K miles, clutch springs rattling so replaced along with slave cylinder.
Post #964764 12th Sep 2022 4:37pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
2012 2.2 110
- first clutch changed due to slave cylinder failure - but clutch it self was changed due to poor condition at the same time - clutch under warrantee - not sure of the milage at that time.
- 2nd clutch changed 4 yrs later after intermittent problem - proved to be spigot bearing - clutch and other systems in good order, however LOF clutch fitted and both master/slave cylinders changed at the same time for upgraded versions, as was the output shaft at the same time.
Not sure of the actual milage but probably in the region of 50k between the changes
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #964779 12th Sep 2022 6:18pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
2013 2.2 110SW
Clutch / slave cylinder and spigot bearing replaced at 69K miles. Slave cylinder seemed to be sticking when operating the clutch pedal which was the reason for doing the work. Fluid was very dark even after recent fluid change. Clutch plate material was fine although springs were loose.
Post #964859 13th Sep 2022 1:16pm
LR90XS2011
2011 def90
from memory
original replaced at about 11k rattling replaced by LR
second rattling when car was at about 22k (11k ish) replaced by IRB with LOF roadspec
LOF one rattled the transmission worse than the knackered LR ones, it rattled the transmission annoyingly for about the first 10k or so but has slowly settled down and is now at 44k (22k) and not rattling the transmission nearly so much, now infrequent (I believe LOF may have addressed this on later drive plates with different damper springs in the centre)
I didn't see the first one but the second one had very loose main springs although they were not about to come out and the flywheel and pressure back plate were unmarked DEFENDER 90 TDCI XS,
Post #964871 13th Sep 2022 1:55pm
I have had mine (3rd) clutch fitted today, it was a friction plate spring that had let go on clutch no2. (Luckily came out between the friction plate and cover).
Flywheel in good condition @ 88k and output shaft also in good condition again at @88k.
So new MC (I fitted that). slave and clutch kit went in. Output shaft and splines regreased and refitted and flywheel fine as it was which is the original.
I thought this thread would be interesting, as you can see a bit of a pattern between wear characteristics as each person posts.
I am hoping this time will have more longevity to it, hopefully. Mr. Green _\Hennessey|Venom| F5/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #964929 13th Sep 2022 9:42pm
Simon dlb
Kenya
30k miles for clutch, but only because I had the gearbox out for the slave cylinder. Also did the power output shaft. Clutch was in pretty poor condition too. Puma 2.4 2010
Post #965441 19th Sep 2022 1:38pm
I'd have to dig out the records for exact numbers but as I recall my 2007 Defender is on its fifth clutch with number six waiting to go in asap, and every one has been replaced due to the failure of the springs in the driven plate. It is on its second slave cylinder (I replaced the original when I fitted the last clutch at about 150k miles because it seemed a good idea) and original master cylinder. Clutch five has done better than the preceding four and has lasted 110k miles but now has no springiness in the driven plate and is pretty unpleasant. It had the first two clutch changes under warranty during its first two years and was on number three by the time it reached 30k miles.
There is no doubt that the early Puma clutches were really, really bad. They have improved however, and are now just not very good. My next will be a 4x4 Transit driven plate which is supposedly better.
We should however be thankful that JLR did at least revert to a single mass flywheel and sprung driven plate and move away from the disaster that was the TD5 DMF.
Post #965447 19th Sep 2022 3:50pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
What DMF disaster on TD5? Have seen quite a lot of cars, with more than 300 000 km done on original clutch and DMF. On our D2 I have 240 000 km on original DMF, at 140 000 km clutch was replaced, because of gearbox overhaul, and it has still 50%. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #965503 20th Sep 2022 11:07am
piechipsandpeas
Blackwolf, what clutches have you had fitted, have they all been standard LR or a mixture of aftermarket types?
Post #965510 20th Sep 2022 12:27pm
Up until now they have all been genuine LR of whatever spec was latest at the time. The one I have waiting to go in is a Transit 4x4 clutch, since I've heard good things about them.
It is worth noting that the first clutch in my '07 lasted under 10k miles, the most recent 110k miles (more than twice the mileage I've ever got from a TD5 DMF, by the way). LR has slowly managed to improve them.
Post #965524 20th Sep 2022 1:52pm
Page 1 of 3 123>
