![]() | Home > Technical > Death wobble |
Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970 ![]() ![]() ![]() |
Death Wobble in a Defender…. You need to get a motorbike to experience that properly😉 Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403 ![]() ![]() ![]() |
Start cheap.
Check for worn bushes, check for something loose. Then work your way up. 👍🏻 2002 td5 90 county hardtop |
Also do a four point wheel swap just as a precaution because if you have a slightly buckled wheel it could change the dimension of the problem Ride like you stole it!!
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2460 ![]() ![]() |
Along with bushes check the A frame ball joint atop the rear axle.
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
Agree with this - first change front wheels for back. Easy to do and costs nowt! |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2379 ![]() ![]() ![]() |
Panhard rod bushes if it's a violent fast judder or swivel preload.
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2026 ![]() ![]() ![]() |
Have you fitted wheel spacers at all? 2023 Defender L663 V8
2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 367 ![]() ![]() ![]() |
Swivel pin preload.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4812 ![]() ![]() |
If the wheels were balanced some of the balancing weights could have come off. Get the front ones at least checked to see if they need balanced. It's an inexpensive move that could solve your problem. 1982 88" 2.25 diesel
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1401 ![]() ![]() ![]() |
Nope Euro-Leafing to infinity and beyond..... |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5347 ![]() ![]() |
i would do this 1st, i suspected i had the same thing, so me and my dad put the car up on the jack and had a go at moving the wheels for any play etc. We couldn't find anything at all. Went down to my local tyre garage and got the front wheels balanced, both needed re balancing, the driver side was well out. by 100 gram Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
some wheel spacers are tight on some alloys and can catch when putting the wheel back on 2023 Defender L663 V8
MR_JAMES Member Since: 10 Oct 2013 Location: ESSEX Posts: 264 ![]() ![]() ![]() |
My series 109 did that around 50mph it was horrendous, swapped the wheels around from front to back and it went away. 1953 80"
1987 mini city e 2011 90" |
Just an update - I had the wheels checked for balance and they were fine. I had also developed a rattle which sounded like brake pads, but still rattled on rough ground whilst braking. Further examination has revealed that the lower bushes on the rear shocks are shot - so that is causing the rattle, hopefully once replaced it will cure the steering issue too. Euro-Leafing to infinity and beyond.....
