Home > Td5 > Under-dash (aircon) fan lost speed I and II, III still ok |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 274 |
Sounds highly likely that the resistors have gone on the blower motor. Only on speed 3 does the full current flow from the motor to the switch, in positions 1 and 2 current flows via resistors and hence the lower speeds. I'm not sure for certain but I think the resistors are nestled nice and tight on the motor in the passenger footwell, really hard to get to. The part number you need is JGM100130, item 5 in the pic below
Good luck! Click image to enlarge Click image to enlarge |
6th Sep 2022 1:43pm |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 324 |
thanks a lot for th einfo, but if it's indeed hard to get to . Do you think this can be fixed in-situ or will I need to bleed/empty the A/C and remove the entire unit to get access? Defender 130 HCPU Td5 MY2000
6th Sep 2022 4:19pm |
I just had a good rummage in the footwell of mine...impossible to get to, the unit will have to come out I'm afraid.
6th Sep 2022 4:23pm |
Of course it has to
Nothing is ever easy, is it? Thanks for the info though, much appreciated and I learned something new today about how heater fans work Defender 130 HCPU Td5 MY2000 |
6th Sep 2022 4:31pm |
Me too! I thought LR would do it the easy way and fit the resistors in the switch which is easy to get to, but oh no...they thought better!
6th Sep 2022 4:32pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16883 |
The resistors get hot so are placed near the fan for a bit of cooling.
6th Sep 2022 7:20pm |
You'd have thought there was enough cooled, ducted air in that system that the resistors could be placed somewhere more convenient. Just below my left knee would be a perfect spot, consistently at or around 10 degrees C!
6th Sep 2022 10:29pm |
I'm not sure the designers did "convenience"! In fact I'm not sure "thought" was.involved in the design process.
6th Sep 2022 11:06pm |
