Home > Td5 > Under-dash (aircon) fan lost speed I and II, III still ok
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
Hi, last week or so, I lost speed I and II on my under-dash fan (a.k.a. aircon). Note that speed III (hurricane setting, at least in terms of noise...) still works, and the cooling part of the A/C also seems to be working fine. Since this is not a total loss of the fan function, I suspect it's not a blown fuse but the switch itself? Is this a known issue with typically an easy fix?
In case of any confusion, I am referring to the rotary switch that controls the fan speed, not the A/C, as in the image below:
 Defender 130 HCPU Td5 MY2000
Post #964153 6th Sep 2022 12:29pm
Penfold_6290
United Kingdom 2002 Defender 110 Td5 CSW Epsom Green
Sounds highly likely that the resistors have gone on the blower motor. Only on speed 3 does the full current flow from the motor to the switch, in positions 1 and 2 current flows via resistors and hence the lower speeds. I'm not sure for certain but I think the resistors are nestled nice and tight on the motor in the passenger footwell, really hard to get to. The part number you need is JGM100130, item 5 in the pic below
Good luck!
Post #964158 6th Sep 2022 1:43pm
RoadForce
thanks a lot for th einfo, but Censored if it's indeed hard to get to Big Cry. Do you think this can be fixed in-situ or will I need to bleed/empty the A/C and remove the entire unit to get access? Defender 130 HCPU Td5 MY2000
Post #964169 6th Sep 2022 4:19pm
Penfold_6290
I just had a good rummage in the footwell of mine...impossible to get to, the unit will have to come out I'm afraid.
Post #964170 6th Sep 2022 4:23pm
RoadForce
Of course it has to Big Cry
Nothing is ever easy, is it?
Thanks for the info though, much appreciated and I learned something new today about how heater fans work Thumbs Up Defender 130 HCPU Td5 MY2000
Post #964172 6th Sep 2022 4:31pm
Penfold_6290
Me too! I thought LR would do it the easy way and fit the resistors in the switch which is easy to get to, but oh no...they thought better!
Post #964173 6th Sep 2022 4:32pm
The resistors get hot so are placed near the fan for a bit of cooling.
Post #964198 6th Sep 2022 7:20pm
Penfold_6290
You'd have thought there was enough cooled, ducted air in that system that the resistors could be placed somewhere more convenient. Just below my left knee would be a perfect spot, consistently at or around 10 degrees C! Rolling with laughter
Post #964223 6th Sep 2022 10:29pm
I'm not sure the designers did "convenience"! In fact I'm not sure "thought" was.involved in the design process. Rolling with laughter
Post #964229 6th Sep 2022 11:06pm
