![]() | Home > Maintenance & Modifications > Installed Wingtop Chequers Plate! |
| Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970
Nice, I wanted to do the same on my Fiji white but I have a black bonnet so it might be too much
If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
| Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 396
Looks really smart, good addition I'd say, I've got a soft spot for white Defenders. Only thing to do now is move your steering wheel to the correct side and you've got the machine sorted!
| steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076
That’s looks great 👍
Only thing I found is that all defenders I checked have an extra 5mm gap on the Left hand side. How can they all be out lol. Didn’t notice on my black 110 but on the silver one it bugs me |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2673
Just now need to add the wing top accessory…..
Click image to enlarge |
| X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2304
Hello Soulrider911
Good job and looks well done... I'm heading in your direction too with our 110 which came to us 'stock'... having now lived with our 90 and its pre-installed checker plate wing tops they overall (IMO) are a practical modification... you effectively have two resting positions for 'stuff' which you wouldn't use without some sort of protection. Its probably the case that if you have these areas that you can stand on or use generally when out in the field then you will find uses without damaging your vehicle. I've also heard... very occasionally some owners even have to work on their trucks with tools involved Click image to enlarge Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
| Soulrider911 Member Since: 04 Jul 2022 Location: California Posts: 119
X4SKP, both of those are amazing! What a great setup. Yes I totally agree the wingtop protectors as super for resting tools on, I was literally doing it yesterday
2022 Defender 110 SE DIY’er | Always learning |
Hello Soulrider911
Not everyone is a fan of checker plate...but it could be worse, I still find it amazing that Land Rover installed plastic checker plate on non-flat surfaces for the New Defender it has taken the aftermarket suppliers to semi-correct this with alloy swap over parts. Good Luck with yours... Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
Thank you! Yes I have a new defender and the plastic checker plate on the hood surprised me when I found out it was plastic not metal 1989 Defender 90
If you're feeling brave...
https://newdefendermods.com/products/new-d...net-plates You get to experience two different worlds then... Good luck with both... https://www.defender2.net/forum/topic83242.html |
| Bowbearer Member Since: 12 Aug 2022 Location: Norfolk Posts: 223
Checker plate is great for climbing on your truck it wet weather. Non slippy.
Hurts when you fall off even from that height. Perfect when you have a front opening roof tent. Other bonus is that it is a flat non combustible surface for the volcano kettle. Did you bonnet as well as it is makes a good platform for pruning trees. |
