Home > In Car Electronics > Flip image on optimill reverse cam and alpine head unit?
Page 2 of 2 <12
nitram17
Co1 wrote:
Can confirm, I cut the green loop only and it has flipped the image the correct way.
So you left the white wire intact? the reason i ask is that mud sent me a replacement camera and i misread the instructions and cut both Embarassed Embarassed the green and white cable as i had your post about the two loops in my head Embarassed i have reconnected them but nothing works....
so i dont know whether the camera was a dud to begin with.......im hoping that you did the same as me and cut both wires but then realized it was just the green wire you had to cut and rejoined the white wire and it worked?
Post #962894 25th Aug 2022 6:01pm
Co1
I left the white intact. Does it still work having cut both?!!
Post #962897 25th Aug 2022 6:16pm
nitram17
That's the problem it doesn't and i didn't check the camera before i cut it Embarassed Embarassed so i dont know if it was a dudd.i will have to google to see what those two wires actually do and whether they stop the signal if cut or just change its orientation.
this will go down in my less rush pay more attention list of cockups!
Post #962898 25th Aug 2022 6:20pm
Co1
There isn’t a lot of slack on them either. Can you at least pare back the white one and solder it back together?
Post #962900 25th Aug 2022 6:25pm
nitram17
im going to try that tonight if i get time ..i did a quick burn of plastic and twist together earlier but that didn't work!
edit it didnt work ..so i think the camera is a dud!
further edit.... after help from mr google......the green wire is for the image orientation and the white wire is for the tramlines....camera should work even if both are cut.
Post #962902 25th Aug 2022 6:29pm
Page 2 of 2 <12
