Home > Puma (Tdci) > Running In Oil
Puma22
Running In Oil
Does anyone have any experience or recommendations for the best type of oil to run in a Puma 2.2 TDCI?
Most running in oils don’t provide a Low saps or ACEA grade. Given the Puma has a DPF I want to ensure I use the correct oil.
Thanks
Post #962588 23rd Aug 2022 7:37am
Caterham
isn't it a bit late for running the engine in ?
if not then lucky you Thumbs Up
reference the SAP I wonder how long you run in and therefore how much soot you're likely to generate.
the other thing to mention is I've run a 1.6 Polo on regular oil with no DPF issues although I was advised I probably would.
sorry not really the answer you were looking for. good luck.
Post #962590 23rd Aug 2022 7:59am
Balvaig
Of all the modern cars I have had from new, including Discoverys and Defenders none have recommended running in oil.
I would be concerned that out of spec running in oil could do much more damage to the modern engine.
The usual recommendation is to use normal oil and proceed gently and unstressed for the first 1000 miles with no oil change until the service interval.
If you wanted to be ultra cautious then an oil and filter change at 1000 miles would not come amiss.
Post #962592 23rd Aug 2022 8:20am
BrickBox
Modern engines are normally bench run-in before fitting. They don’t require thinner mineral oil etc. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #962593 23rd Aug 2022 8:32am
Leamreject
Italy 2011 Defender 90 Puma 2.4 HT Fuji White
If the engine is supplied with oil it may be running in oil where they have bench tested it, but I would still drain and replenish it with fresh and do a filter cartridge change for piece of mind. Ride like you stole it!!
If I’m not on a bike it’s because only a 4x4 will do…
2011 2.4 Puma 90 HT
Post #962595 23rd Aug 2022 8:58am
Puma22
Hi all. I am mid way through a rebuild. So the engine will need running in.
This isn’t for a new engine or supplied reman one.
Thanks.
Post #962598 23rd Aug 2022 9:18am
sharkey964
France 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
I bought a new/rebuilt Td5 engine from Turner Engineering last year,& they supplied running in oil for it.I ran it for the first 1000km with it in,then changed to my usual synthetic oil.
Marc.
Post #962611 23rd Aug 2022 11:42am
Puma22
Did they make any comments around using mineral oils and non low SAPS oils with a DPF.
Post #962613 23rd Aug 2022 12:00pm
sharkey964
No,just run for the first 1000 miles with the running in oil.
Marc.
Post #962658 23rd Aug 2022 6:44pm
Puma22
Thanks Marc
Post #962684 23rd Aug 2022 8:31pm
None of that is relevant with a TD5 but it may be worth a call to Turners as I believe that they now offer rebuilt Puma engines, too. Darren
Post #962715 24th Aug 2022 8:27am
Puma22
I have just spoken with Turners and Westway Lubricants. Both have advised that due to the time the oil is in the engine, there is no risk to the DPF. - Assuming you stick with the recommended run time and oil change. Apx 4hrs/500miles.
Post #962716 24th Aug 2022 8:33am
