![]() | Home > In Car Electronics > Is the reverse camera signal ground actually a shield? |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3641 ![]() ![]() ![]() |
When I installed my reverse camera, I did not have a phono cable that was long enough, so I simply cut the one I had in halve and spliced a 2 core in the middle. The video quality was not any worse than when I tried it with a the proper shorter phono cable.
I think the ground was also a shield on the original cable. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784 ![]() ![]() ![]() |
Thanks Dinnu. So is there just the 2 cores, or 2 cores and a shield?
If I recall correctly its one core and a shield. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Cheers.
Just to be clear.. my camera is not optomill, and just use a standard video jack (phono). It is the phono cable that connects between the camera video jack and the monitor video jack that I extended. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
Normal composite video (as reversing cameras usually are), is just a centre single core with the signal on it, surrounded by the shielding jacket (braid or foil)
I can confirm that the optimill camera is just a 2 core cable, no shield.
