Home > In Car Electronics > Is the reverse camera signal ground actually a shield?
Co1
Won’t bore you with the details, but I need to make off the signal cable again on my optimill reverse camera. Will there be 2 cores in the cable or 1 core and a shield? If it’s the latter, does anyone know if that’s a foil shield or a braided shield?
Col
Post #962253 19th Aug 2022 4:08pm
Dinnu
When I installed my reverse camera, I did not have a phono cable that was long enough, so I simply cut the one I had in halve and spliced a 2 core in the middle. The video quality was not any worse than when I tried it with a the proper shorter phono cable.
I think the ground was also a shield on the original cable. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #962257 19th Aug 2022 4:28pm
Co1
Thanks Dinnu. So is there just the 2 cores, or 2 cores and a shield?
Post #962268 19th Aug 2022 5:11pm
Dinnu
If I recall correctly its one core and a shield. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #962277 19th Aug 2022 7:42pm
Co1
Cheers.
Post #962278 19th Aug 2022 7:45pm
Dinnu
Just to be clear.. my camera is not optomill, and just use a standard video jack (phono). It is the phono cable that connects between the camera video jack and the monitor video jack that I extended. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #962280 19th Aug 2022 7:53pm
Normal composite video (as reversing cameras usually are), is just a centre single core with the signal on it, surrounded by the shielding jacket (braid or foil)
Post #962418 21st Aug 2022 5:14pm
Co1
I can confirm that the optimill camera is just a 2 core cable, no shield.
Post #962420 21st Aug 2022 5:27pm
