Home > Maintenance & Modifications > Key Fob 2016
PWC1c
United Kingdom 2015 Defender 110 Puma 2.2 SW Auto Santorini Black
Key Fob 2016
Any ideas on key fob refurb ?
Rubber casing is coming apart or is it best to buy new ones .
Post #962042 17th Aug 2022 7:37pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
The rubber seems to part company with the underlying plastic case no matter what you do. Glueing doesn’t appear to work and you need to separate the case halves to replace the battery.
I had a look for a suitable silicon cover instead and use something like this https://amzn.eu/d/hIrk2YW. Works just fine and isn’t too bulky. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #962048 17th Aug 2022 8:47pm
The Zee
I assume the key type you are refering to the "long chrome strip" type :
Part numbers LR078922 or C2D49508 can provide a back, chrome strip, key ring clip and silicone gasket, the front button panel is designed for the 4 button Disco/RR/Evoque, and while it will not be an "exact" copy of the original key fob, (it has a gloss Land Rover logo back) it will refresh your fob if the damage is to the back, or chrome strip.
I'll try to take some images to illustrate the diffrences Zaid-M
www.DefencePhotos.com
Post #962103 18th Aug 2022 10:16am
PWC1c
Key Fob
Thanks for the replies much appreciated
Post #962484 22nd Aug 2022 9:54am
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I have not used them (yet), but they seem to get good reviews on trustpilot... https://www.shop.carkeyssolutions.co.uk/pr...2014-2016/
Post #962547 22nd Aug 2022 7:23pm
The Zee
As promised:
From L-R
Fob 1 & 2 - Standard Fob from JLR for 2.2 Puma Front and Back (1 orginal supplied, other new from JLR Dealer)
Fob 3 - New Part No: C2D49508 Back - Note supplied with chrome stripe, gasket, ring, screw, pin and attachment point - Frount is 5 buttions: Lock, unlock,lights, boot release and emergency hazard
Fob 4 Orginal Std Fob with LRO78922 back fitted for 2 years, slight matt finish due to wear and tear - Similar to C2D49508 but note supplied with gasket, ring, screw, pin and attachment point - NO chrome strip supplied - Frount face for LRO78922 is 5 buttions: Lock, unlock,lights, boot release and emergency hazard (not used) old chrome strip given brush finsh to hide wear and tear.
Hope this helps Zaid-M
Post #962618 23rd Aug 2022 1:04pm
DSC-off
Following previous advice from The Zee Bow down I repaired a fob.
The front of the case was broken and the rubber peeled off the back.
I fitted the circuit board in a 5 button case, blacked out 3 buttons and made the 4th look more like 'unlock' than 'lights'
It's a shame the 2 button case isn't available as spares, only a complete fob that needs programming into the car.
Post #962625 23rd Aug 2022 2:03pm
The Zee
Good job! Thumbs Up
Happy to help. Cool Zaid-M
Post #962626 23rd Aug 2022 2:08pm
The Zee
After all the advice; I'm now in the same predicament Rolling Eyes
I’ve damaged my original 2 button remote for locking/unlocking. Unfortunately, in my situation I’ve cracked the front of the case not the easy to replace back.
Has anybody found a solution to this conundrum, the electronics are fine, just the front looks a mess! Big Cry
Are 2 button cases for the "newer" style fob availabe from anybody? Zaid-M
Post #1074015 24th Aug 2025 8:31pm
dnorrishill
I have not sent mine to them yet, but keep meaning to... They will repair for £113 https://shop.carkeyssolutions.co.uk/produc...2014-2016/
Post #1074049 25th Aug 2025 5:53pm
