![]() | Home > Maintenance & Modifications > Key Fob 2016 |
PWC1c Member Since: 10 Oct 2015 Location: Hertfordshire Posts: 196 ![]() ![]() ![]() |
Any ideas on key fob refurb ?
Rubber casing is coming apart or is it best to buy new ones . |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 371 ![]() ![]() ![]() |
The rubber seems to part company with the underlying plastic case no matter what you do. Glueing doesn’t appear to work and you need to separate the case halves to replace the battery.
I had a look for a suitable silicon cover instead and use something like this https://amzn.eu/d/hIrk2YW. Works just fine and isn’t too bulky. Dave Green Goddess - 1998 Defender 110 300tdi |
The Zee Member Since: 26 May 2019 Location: Salisbury Posts: 303 ![]() ![]() ![]() |
I assume the key type you are refering to the "long chrome strip" type :
Part numbers LR078922 or C2D49508 can provide a back, chrome strip, key ring clip and silicone gasket, the front button panel is designed for the 4 button Disco/RR/Evoque, and while it will not be an "exact" copy of the original key fob, (it has a gloss Land Rover logo back) it will refresh your fob if the damage is to the back, or chrome strip. I'll try to take some images to illustrate the diffrences Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Thanks for the replies much appreciated
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 633 ![]() ![]() ![]() |
I have not used them (yet), but they seem to get good reviews on trustpilot... https://www.shop.carkeyssolutions.co.uk/pr...2014-2016/
As promised:
![]() Click image to enlarge From L-R Fob 1 & 2 - Standard Fob from JLR for 2.2 Puma Front and Back (1 orginal supplied, other new from JLR Dealer) Fob 3 - New Part No: C2D49508 Back - Note supplied with chrome stripe, gasket, ring, screw, pin and attachment point - Frount is 5 buttions: Lock, unlock,lights, boot release and emergency hazard Fob 4 Orginal Std Fob with LRO78922 back fitted for 2 years, slight matt finish due to wear and tear - Similar to C2D49508 but note supplied with gasket, ring, screw, pin and attachment point - NO chrome strip supplied - Frount face for LRO78922 is 5 buttions: Lock, unlock,lights, boot release and emergency hazard (not used) old chrome strip given brush finsh to hide wear and tear. Hope this helps Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
Good job!
![]() Happy to help. ![]() www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
After all the advice; I'm now in the same predicament
![]() I’ve damaged my original 2 button remote for locking/unlocking. Unfortunately, in my situation I’ve cracked the front of the case not the easy to replace back. Has anybody found a solution to this conundrum, the electronics are fine, just the front looks a mess! ![]() Are 2 button cases for the "newer" style fob availabe from anybody? Zaid-M www.DefencePhotos.com 2014 Defender 110 Utility, 2.2 Puma, Indus Silver Not just transport more like a religion |
I have not sent mine to them yet, but keep meaning to... They will repair for £113 https://shop.carkeyssolutions.co.uk/produc...2014-2016/
