![]() | Home > In Car Electronics > Using tdci heated seat switch as a work light switch? |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3746 ![]() ![]() ![]() |
Think I’ve made a wiring mistake. I’m using this switch to switch the positive to my rear work light. I’m thinking it’s not the right switch for this. Am I right? Switch is part no YUF500150LNF.
https://cdn.accentuate.io/4497171775573/11...879548.pdf Cheers Col |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6693 ![]() ![]() ![]() |
Yes that's absolutely fine, it's a positive side switch with internally driven telltale LED.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3596 ![]() ![]() ![]() |
There is a very good wiring diagram on this thread:
https://www.defender2.net/forum/post306063.html#306063 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3674 ![]() ![]() ![]() |
take a look at the MUD website loads of TDCI style switches now available DEFENDER 90 TDCI XS,
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2274 ![]() ![]() |
Why use the seat heater switch?
I used the rear heated window switch. Made sense as (A) I never use the window and (B) all the wiring is already at the back of the vehicle so it’s simple to tie in with 2 worklights at the rear of the 110. Oh and (C) I like a hot bum ![]() |
I haven’t used the actual switch from the heated seat, I bought an extra heated seat switch from MUD and a work light bezel to replace the heated seat bezel and used it in my double din set up for an OEM looking switch. Does that make sense?!!
Ahhhhh
