Home > Td5 > Dashboard retrofit
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
Dashboard retrofit
Hi,
is it possible to retrofit the newer (2001+) dashboard to the previous version (1999)? Given my intention to get a Carplay/Android unit with e screen, I figured it might be an idea to upgrade the center as well in that process (if I end up buying the 1999 TD5 110)
Sorry for the questions - I'm new to the Defender world
Post #961740 15th Aug 2022 2:48pm
DSC-off
As with a lot of Defender updates, retro fitting the dash into an earlier model is possible. If it is worth the cost and trouble is the big question?
The wiring and switches are all different, so there will be a lot of work to connect it up and get it working again.
Many of the plastic moulded parts are different, not just the obvious front plate. Some cannot be bought new anymore and secondhand parts are surprisingly expensive.
Then when it is done, the 'new' dash will have to be modified to fit a 'double din' size modern radio head unit.
It would be much easier and cheaper to fit the Mud centre console and fit a radio in that.
https://www.mudstuff.co.uk/collections/das...er-console
Post #961744 15th Aug 2022 3:31pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Re: Dashboard retrofit
doruk1981 wrote:
Hi,
As already stated I too think it would be easier to install a MUD UK console. Thumbs Up
 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #961767 15th Aug 2022 6:00pm
4RF RDS
doruk1981 wrote:
Hi,
1967 MGB GT
Post #961768 15th Aug 2022 6:00pm
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
4RF RDS really liking those gauges, where are they from? 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #961811 15th Aug 2022 10:35pm
4RF RDS
The main dash cluster is OEM (VDO) with green backlight bulbs however T they’re just aluminum rings off fleaBay around them. And the console gauges are VDO Vision Series.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #961812 15th Aug 2022 10:43pm
doruk1981
really like the retrofit with that aftermarket part.. looks good. I assume the quality will be also just fine. with the alu rings, the dash has a hint of puma
Post #961823 16th Aug 2022 7:28am
