Home > Td5 > Dashboard retrofit |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1351 |
As with a lot of Defender updates, retro fitting the dash into an earlier model is possible. If it is worth the cost and trouble is the big question?
The wiring and switches are all different, so there will be a lot of work to connect it up and get it working again. Many of the plastic moulded parts are different, not just the obvious front plate. Some cannot be bought new anymore and secondhand parts are surprisingly expensive. Then when it is done, the 'new' dash will have to be modified to fit a 'double din' size modern radio head unit. It would be much easier and cheaper to fit the Mud centre console and fit a radio in that. https://www.mudstuff.co.uk/collections/das...er-console |
15th Aug 2022 3:31pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 899 |
As already stated I too think it would be easier to install a MUD UK console. Click image to enlarge 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
15th Aug 2022 6:00pm |
Soulrider911 Member Since: 04 Jul 2022 Location: California Posts: 105 |
4RF RDS really liking those gauges, where are they from? 1989 Defender 90
2022 Defender 110 SE DIY’er | Always learning |
15th Aug 2022 10:35pm |
The main dash cluster is OEM (VDO) with green backlight bulbs however T they’re just aluminum rings off fleaBay around them. And the console gauges are VDO Vision Series.
Cheers 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
15th Aug 2022 10:43pm |
doruk1981 Member Since: 15 Aug 2022 Location: Aargau Posts: 96 |
really like the retrofit with that aftermarket part.. looks good. I assume the quality will be also just fine. with the alu rings, the dash has a hint of puma
16th Aug 2022 7:28am |
