![]() | Home > Td5 > Slip on wheel spacers? |
ChristoCY Member Since: 03 Jul 2021 Location: Larnaca Posts: 2 ![]() ![]() |
Morning folks,
I just fitted 18" sawtooths and Cooper tyres on my 90. At full lock the tyres just catch the radius arms. I took the front wheel off and put a couple of washers as spacers to determine the clearance I need and it's just 6-8mm. Does anyone have a solution? Should I look for 8mm slip-on spacers? Are they safe? Will I still have enough thread left for the wheel nuts? Can anyone recommend a good brand? Cheers |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1910 ![]() ![]() |
![]() ![]() When I rebuilt my P38 front hubs, the lock stops both snapped. It's a meaty enough thread - M12? - so I just fitted a stainless nut. Planning to do the same on the Defender when I put in the refurbed axle "at some stage". Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3615 ![]() ![]() ![]() |
I think the 30mm is also to have enough 'meat' so as not to disintegrate on the 1st bump.
What I had done in the past is use old drum brakes, cut off the excess material, and use the frontal part (I hope my explanation is understandable) as a spacer. I think the thickness is around 5 or 6mm. It reduces the amount of thread available on the studs, but I could get away with it (I used this method to mount alloys on 10 spline hubs). If you need more space, then you can fit 2 modified drum brakes, but then you will need to replace the studs for longer ones as used on Wolfs. But ensure that there is no build up of rust between the multiple surfaces. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
