![]() | Home > Maintenance & Modifications > 300tdi maintenance |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 365 ![]() ![]() ![]() |
1. Not necessary but the washer is.
2. I am not sure. 3. Mine is the later type. The plug head is approximately 15mm. |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4807 ![]() ![]() |
![]() Click image to enlarge Changing the sump plug washer is a good idea. The early 300 tdi is the same as the 200 tdi and is 27 mm across. The later 300 tdi is smaller and is. The washers come in packs of ten and are very cheap.I am sorry that is the best I can do but someone else should have more specific knowledge. If in doubt buy both as they are very cheap! ![]() Click image to enlarge 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11325 ![]() ![]() |
That move was actually made with the TD5 and just continued with the Puma. It's probably just for packaging reasons. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
The circle red is a drain hole for the bell housing. Leave it as it is. You usually get a screw in bung called a wading plug with the Land Rover to screw in when deep wading.
https://www.ebay.co.uk/itm/291484638304?ha...SwU9xUMFiU This looks to be the sump plug you need https://www.ebay.co.uk/itm/370865996814?fi...xys4RR990e Contact them and just get a packet of sealing washers 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
As said above.
The part number for the washer I use is: ALU1403L |
APK Member Since: 13 Jan 2015 Location: London Posts: 255 ![]() ![]() ![]() |
Thank you
![]() MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
Are these the wading plugs J688 and J687? They look different in shape in the Owners handbook (J688 looks like a hexagon and J687 looks like a square head) but the x2 I have in the toolkit look identical. I assume they are aftermarket? Thank you! ![]() Click image to enlarge ![]() Click image to enlarge APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
Look fine 1982 88" 2.25 diesel
Yes, just realised that the Owners Manual shows many more options that the Workshop Manual. Thanks for pointing that out. Workshop Manual ![]() Click image to enlarge Owner's Manual ![]() Click image to enlarge APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
Hi all,
Dealer recommended Castrol SAF-X0 Oil Fluid TYK500010 (£30.95 per litre) for Transfer gearbox and differentials. https://rimmerbros.com/Item--i-TYK500010 Is Castrol TRANSMAX Universal LL 75W-90 a better choice at £17.95 per litre, GL-5 and fully synthetic? https://www.opieoils.co.uk/p-77373-castrol...fluid.aspx 7l in total required for transfer gearbox (2.3l) and front & rear differentials (1.7l + 2.3l). Thank you APK MY2016 110 Adventure Corris Grey MY1997 110 County Station Wagon 300 Tdi Alpine White |
That type of oil in the diffs is not necessary.
A good quality EP90 will be just fine. I used to have Transmaxs 75w90 in the transfer box but I am also starting to think it's too much. |
