![]() | Home > Td5 > Front crank pulley rattle :-( |
Hi John.
238k miles is excellent on a pulley, well done ![]() If you are in there then it is the perfect time to check over the pulleys, bearings and belt. Especially the fan pulley bearing in the front engine cover. |
And a little light reading for you http://www.discovery2.co.uk/CrankPulley.html
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
Cheers. Its done well. It started with a squeak ....
![]() I don't have 3/4 drives or a big enough torque wrench. I have made a few calls and its off to be looked at by a local garage as I could do with it for the weekend (two motorsport events, Anglesey and Weeton army barracks) and need it fixed. Bad timing! 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Thanks, I have seen his article. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Start to finish it shouldn't take more than a couple of hours for a garage. Make sure they use a new bolt with the new pulley. The rest of the "whilst you are in there" can wait for another day
In my head new bolt is a must as is a new pulley. Also a new oil seal as I think this might account for some oil low down on the engine. (along with the rest of the leaks) 1999 Defender TD5 110
Yup that seal does leak a little. Make sure it is a good quality item LR or Corteco or similar.
cheers. 1999 Defender TD5 110
Just one more thing. The leak may not be coming from that seal but from the vacuum return from the alternator/vacuum pump to engine block. These get hard and leak/weep. it will be right there next to the crank.
Page 20 of the Miffy thread you can see the offending article. You cannot buy this part, but it is essentially just standard pipe, specs in the post; https://www.defender2.net/forum/topic53859-285.html |
I saw your thread and ordered the hose and clips, just not got that far yet.
![]() Regards John M0VAZ Econet Station 48 no clock |
Since they are there get the garage to fit the pipe. they'll have the belt off anyway.
True. I have had the belt of a few times so I am not bothered about that job, gives me time to clean up the area. 1999 Defender TD5 110
Now the question is. Genuine LR pulley or after market. So many choices
£88 for a OE QUALITY ? £440 Gen LR Turner Engineering Britpart.... ? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I went for a OE pulley. Quality looked good, still working as of now
