Home > Maintenance & Modifications > LED kit drill new holes??
Soulrider911
United States 1989 Defender 90 2.5 TD SW Chawton White
Hey Friends.
So, I got an led kit and I was all ready to start installing them and I noticed something peculiar. On my 89 Defender, the existing lights (not the headlights) are all mounted to the body via 3 screws, and then 2 screws mount the lens to light base.
All the LED kits I am finding the lights mount with only 2 screws. Before I go drilling holes everywhere I thought I would check to ensure I might have the wrong kit... or this is just standard procedure.
Thank you
 1989 Defender 90
2022 Defender 110 SE
DIY’er | Always learning
Post #959650 27th Jul 2022 12:33am
Soulrider911
Apologies the answer was right under my nose on YouTube. Yes drill holes you must 1989 Defender 90
Post #959652 27th Jul 2022 1:55am
As you've found, the earlier ones are different, unfortunately. I think it changed with the introduction of the 300tdi in '94 when they went over to the one piece lamps and Econoseal connectors. Darren
Post #959667 27th Jul 2022 9:07am
DSC-off
There are plinths available to fit front NAS type lights, but the 2 types I've found have only 2 holes.
Maybe the plinth could be redrilled to match your holes, instead of drilling the body.
Both aluminium and plastic ones available.
https://www.optimill-uk.com/front-light-plinth.html
https://www.ebay.co.uk/itm/220727184560
Post #959673 27th Jul 2022 10:07am
