Home > Td5 > ECU Purple wire |
geobloke Member Since: 06 Nov 2012 Location: Nottinghamshire Posts: 4407 |
That does not look standard to me. What pin does it go to in the black plug?
Could be that a previous owner had a boost box installed. The pin number will help ID it. |
24th Jul 2022 6:10pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Interior light switches for second row doors. Assuming yours is a 90/3dr?
Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
24th Jul 2022 6:53pm |
andy2111 Member Since: 17 Oct 2021 Location: Kent Posts: 365 |
It's a 110 hardtop 3 door, so assume it's redundant as for another model?
24th Jul 2022 7:24pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6484 |
Wouldn't be going to the ECU though. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
24th Jul 2022 8:52pm |
Is it my imagination or does that purple wire turn black and white after the red sleeving?!
25th Jul 2022 9:52am |
yes it does - it definitely looks like a add-on of some description.
Will take a look at what pin it goes into on Saturday and post an update |
27th Jul 2022 4:43pm |
I had a look at the weekend and tracing the wire back it doesnt go into the ECU, it originates through the same hole in the seatbox that the ECU loom comes through, so looks like it is some old add-on from a previous owner that just poked it through the same hole. Mystery solved (ish)!
2nd Aug 2022 8:30am |
Time to get ion your back and trace it along the chassis and then probably in to the dash via another gland in the bulkhead.
It is a thin wire so probably only a signal wire... Rev gauge... Temp gauge perhaps. At least it is not critical... |
2nd Aug 2022 10:17am |
