Home > Td5 > ECU Purple wire
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
ECU Purple wire
Does anyone know what this purple wire and connector does? It runs into the black ECU connector and I found it tucked away under the ECU
CU.
Post #959392 24th Jul 2022 5:34pm
geobloke
That does not look standard to me. What pin does it go to in the black plug?
Could be that a previous owner had a boost box installed. The pin number will help ID it.
Post #959399 24th Jul 2022 6:10pm
rallysteve
Interior light switches for second row doors. Assuming yours is a 90/3dr?
Post #959404 24th Jul 2022 6:53pm
andy2111
It's a 110 hardtop 3 door, so assume it's redundant as for another model?
Post #959405 24th Jul 2022 7:24pm
Martin
Site Admin
Steve
Wouldn't be going to the ECU though.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #959414 24th Jul 2022 8:52pm
geobloke
Is it my imagination or does that purple wire turn black and white after the red sleeving?!
Post #959438 25th Jul 2022 9:52am
andy2111
yes it does - it definitely looks like a add-on of some description.
Will take a look at what pin it goes into on Saturday and post an update
Post #959726 27th Jul 2022 4:43pm
andy2111
I had a look at the weekend and tracing the wire back it doesnt go into the ECU, it originates through the same hole in the seatbox that the ECU loom comes through, so looks like it is some old add-on from a previous owner that just poked it through the same hole. Mystery solved (ish)!
Post #960272 2nd Aug 2022 8:30am
geobloke
Time to get ion your back and trace it along the chassis and then probably in to the dash via another gland in the bulkhead.
It is a thin wire so probably only a signal wire... Rev gauge... Temp gauge perhaps. At least it is not critical... Thumbs Up
Post #960279 2nd Aug 2022 10:17am
