Home > Technical > Galvanic corrosion
ScarboroughSeadog
United Kingdom 2013 Defender 110 Puma 2.2 DCPU Keswick Green
Galvanic corrosion
I’m familiar with the corrosive effect of steel next to aluminium from my 45 year old lightweight, but had hoped LR might have looked to mitigate the issue by 2013!
My Puma has serious holes in the second row aluminium footplate- and in areas not in direct contact with steel. Grateful for any comments and solutions. Plate over with a new aluminium section from the inside, with appropriate isolation washers between the metals? Is a pre-formed floor section available?
Thanks
Post #959321 23rd Jul 2022 9:57pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
YRM seem to be the go to place for metalwork. That would be my first point of call.
Post #959333 24th Jul 2022 3:54am
rustandoil
Further inspection required there....I have a feeling you'll find a lot more misery 😥
Post #959334 24th Jul 2022 7:23am
bodstruck
I had this level of corrosion on my 05 110. I was shocked at that given its age but a 2013 Shocked
As said above, a replacement panel from YRM will be the solution. They do complete upstand which are riveted in place. It is not a horrendous job but does take a while. On the plus side, while you have the floor panel and upstand off it gives good access to assess/clean the crossmember and top of the chassis rails. Perhaps also replace the floor plate screws with SS and as you say, isolate everything when it goes back together.
Post #959335 24th Jul 2022 8:23am
ScarboroughSeadog
Thanks guys- YRM seems to be the place to go, and not too far from me either. I’m wondering if the degree of corrosion is due to some electrical or earthing issue- the vehicle has been fitted with a VHF radio from new (2013) and in very regular use. Just trying to think of reasons the aluminium corrosion is so bad- particularly in sections which aren’t in immediate contact with steel…..
Post #959339 24th Jul 2022 9:06am
Jerry
2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
Would your seaside location affect this type of corrosion?
Post #959340 24th Jul 2022 9:22am
ScarboroughSeadog
The vehicle has spent most of its life in Scotland and Cumbria- but don’t think it should do in any event.
Post #959347 24th Jul 2022 10:58am
rustandoil
If you get to have the floor and the upstand out, consider replacing the body crossmember, the YRM version with the bolt on brackets is good 👍🏻
Post #959360 24th Jul 2022 12:56pm
