![]() | Home > Technical > Galvanic corrosion |
ScarboroughSeadog Member Since: 21 Jul 2022 Location: Scarborough Posts: 110 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge I’m familiar with the corrosive effect of steel next to aluminium from my 45 year old lightweight, but had hoped LR might have looked to mitigate the issue by 2013! My Puma has serious holes in the second row aluminium footplate- and in areas not in direct contact with steel. Grateful for any comments and solutions. Plate over with a new aluminium section from the inside, with appropriate isolation washers between the metals? Is a pre-formed floor section available? Thanks |
Mossberg Member Since: 29 Feb 2020 Location: Lancs Posts: 553 ![]() ![]() ![]() |
YRM seem to be the go to place for metalwork. That would be my first point of call.
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 860 ![]() ![]() ![]() |
Further inspection required there....I have a feeling you'll find a lot more misery 😥
Thanks guys- YRM seems to be the place to go, and not too far from me either. I’m wondering if the degree of corrosion is due to some electrical or earthing issue- the vehicle has been fitted with a VHF radio from new (2013) and in very regular use. Just trying to think of reasons the aluminium corrosion is so bad- particularly in sections which aren’t in immediate contact with steel…..
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 205 ![]() ![]() |
Would your seaside location affect this type of corrosion?
The vehicle has spent most of its life in Scotland and Cumbria- but don’t think it should do in any event.
If you get to have the floor and the upstand out, consider replacing the body crossmember, the YRM version with the bolt on brackets is good 👍🏻
