Home > Puma (Tdci) > Crankcase Pressurised
Page 2 of 3 <123>
Puma22
I tried annealing on 2 of the cylinders, again no luck.
I’ve read 6Nm, but that doesn’t seem enough? - I’ve got 2 new genuine bolts coming next. I’ve read that they are stretch bolts, so perhaps other brands are inadequate?
Post #956535 25th Jun 2022 10:53am
hank
On 2.4 it is 6Nm plus 180 degrees. Not sure whether this is the same for 2.2 > 110 XS Double Cab
Post #956623 27th Jun 2022 8:23am
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
The extra 180 deg might explain why they are leaking.
Mark
Post #956631 27th Jun 2022 10:33am
Puma22
I have now changed the bolts for genuine LR ones, there was a very slight length difference. However I still have the blowby.
I now have another fault code, "P2263-22 (EC) Turbo/supercharge boost system performance - General signal failure - signal amplitude&gt;maxiumum"
Does anyone know if this can be related to blowby and should I start to look at the turbo, or is this perhaps a conincidence and I now have 2 faults.
Post #957245 4th Jul 2022 1:50pm
ickle
Possibly disturbed the loom to the turbo? Notorious weak spots over the air con pump and around the ferrite ring.
I was always told to use new stretch bolts and anneal the washers even if genuine.
HTH Keith
Post #957269 4th Jul 2022 4:45pm
Puma22
I seen this is a problem on the 2.4's, so I checked mine and it must be a different loop as there is plenty of length on mine.
Post #957270 4th Jul 2022 4:46pm
ickle
IIRC there is a ferrite ring wrapped into the loom just near the multi plug connector on the turbo - pretty sure someone on here had the wire fail on this ring.
Good luck
Keith
Post #957273 4th Jul 2022 5:17pm
Puma22
I have now checked the loom and disconnected the actuator to prove this is not sticking. Another item rules out.
Post #957391 5th Jul 2022 8:21pm
Puma22
For information the result here is a cracked piston. I’m waiting to hear about the injectors, but it’s suspected a faulty injector caused this.
Post #958175 13th Jul 2022 5:14pm
Big Harold
Bingo!
However I don't believe in the injector theory, I believe that the pistons are the issue.
The failure mode is exactly like the Toyota pistons in Australia and there has been 3 updates to pistons but no injector updates.
Your options are buy just one piston if it hasn't damaged the bore or buy a set and rebuild.
I bought a rebuild kit from Lyme Parts for $1200 Aus that was landed, so pretty decent in my book.
Mark
Post #958237 14th Jul 2022 3:05am
Puma22
Are the Lyme pistons different to the OEM ones? Are they any less likely to crack?
I think a full rebuild is the best option. Luckily there are no markings on the walls.
Post #958251 14th Jul 2022 8:35am
Puma22
All injectors have been tested and returned to me, all tested okay. So it appears this might just be a defect with the pistons themselves? I’ve heard many stories of no3 piston cracking.
Post #958428 15th Jul 2022 2:48pm
Dinnu
If you want to see a cracked piston, then have a look at this:
https://www.defender2.net/forum/topic76287.html
Is your 2.2 on standard map, or was it tuned? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #958429 15th Jul 2022 3:22pm
Puma22
It was tuned, with a larger intercooler. But this was removed (due to clutch wear) before the fault occurred.
Post #958431 15th Jul 2022 3:26pm
Puma22
Looking at your pistons, mine is not so bad.
I would like to know the root cause before rebuilding.
Post #958432 15th Jul 2022 3:29pm
Page 2 of 3 <123>
