![]() | Home > In Car Electronics > Mounting speakers in roof of 110 DCPU? |
Penfold_6290 Member Since: 22 Sep 2021 Location: Dorset Posts: 394 ![]() ![]() ![]() |
Have you considered putting them in the doors? That's where I've put some in my 110 CSW. I doubt the LR headlining will support the weight of a speaker - mine is sagging under its own weight, without the help of a pair of 400g speakers.
I pair of 10cm or 13cm speakers with a spacer would fit a treat. I have 10cm speakers in mine using the genuine Land Rover speaker spacer that normally goes under the dash. It just steps the magnet out of the way of the window winding mechanism. Ignore the arrow, speaker can be seen in situ in nearside rear door ![]() Click image to enlarge |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
La Salle do a headling which includes a speaker part, if you wanted to replace the entire headlining to fix the sag, but it is not a cheap option!
https://www.lasalle-trim.co.uk/product/dou...oors-trim/ 2005 Td5 90 XS 1989 V8 110 CSW |
phillips321 Member Since: 16 Dec 2021 Location: UK Posts: 103 ![]() ![]() |
In the end I decided to go with fitting behind the seats in the corners.
A little CAD work (Cardboard Aided Design) for some aluminium panels and some dirty seam sealer and they’re in. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2221 ![]() ![]() ![]() |
Was coming on to post the same thing you posted phillips!
Exactly what I did, then mounted the tweeters in the C pillar below the seatbelt and an amp on the rear bulkhead. Worked perfectly |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 867 ![]() ![]() ![]() |
Same...did mine in MDF,seems to have stood up quite well.
I mounted mine using two M5 tapped holes that are in my C pillar. Edit: spelling |
