Home > Maintenance & Modifications > 130 HCPU brackets |
Bradders130 Member Since: 27 Nov 2021 Location: Southampton Posts: 75 |
So my next issue with installing my second hand 130 tub is the gap (about 5mm) between the Angle reinforcing bar-MTC4156 and the bracket MTC4002. Here is a photo...
Click image to enlarge Click image to enlarge Click image to enlarge I thought that it may take the plate, listed as item no. 17 - MTC6154 on LR Workshops |
21st Jun 2022 9:10pm |
Sorry guys, user error, for some reason it seems that my previous post was cut short...
So as I was saying I thought that it may take the plate, listed as item no. 17 - MTC6154 on LR Workshops as per the photo below... Click image to enlarge That is the right size, but it's listed as requiring 4 when I'm pretty sure I only need 2, unless someone knows otherwise. Any right direction pointers will be gratefully received. |
22nd Jun 2022 12:12am |
Anyone at all? There must be some 130 owners who know or can have a quick look under the back of their tub.
23rd Jun 2022 12:08am |
Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 848 |
From this photo (lifted from AndrewS), it appears you've got the correct bracket arrangement.
Click image to enlarge I would suggest a shim or two is required, from this listing it appears that MTC6154 is a shim as opposed to a nut plate - https://www.ebay.ch/itm/384158591930?hash=...SwZHNgmo74 1985 127 V8 Build Thread Series 2 109" Series 1 80" |
27th Jun 2022 8:03am |
That’s great confirmation Shroppy, thanks. I think is off to the local Metal Supermaket then. £30.20 is crazy money for a shim!
27th Jun 2022 8:15am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6038 |
That under body picture reminds me of how shoddy the paintwork was on defenders
29th Jun 2022 5:27am |
Yep, I’ve just finished spraying the underside of the tub with Raptor. Looks good
29th Jun 2022 8:02am |
