Home > Maintenance & Modifications > 130 HCPU brackets
Bradders130
United Kingdom 2012 Defender 130 Puma 2.2 HCPU Indus Silver
130 HCPU brackets
So my next issue with installing my second hand 130 tub is the gap (about 5mm) between the Angle reinforcing bar-MTC4156 and the bracket MTC4002. Here is a photo...
I thought that it may take the plate, listed as item no. 17 - MTC6154 on LR Workshops
Post #956145 21st Jun 2022 9:10pm
Bradders130
Sorry guys, user error, for some reason it seems that my previous post was cut short...
So as I was saying I thought that it may take the plate, listed as item no. 17 - MTC6154 on LR Workshops as per the photo below...
That is the right size, but it's listed as requiring 4 when I'm pretty sure I only need 2, unless someone knows otherwise.
Any right direction pointers will be gratefully received.
Post #956166 22nd Jun 2022 12:12am
Bradders130
Anyone at all? There must be some 130 owners who know or can have a quick look under the back of their tub.
Post #956275 23rd Jun 2022 12:08am
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
From this photo (lifted from AndrewS), it appears you've got the correct bracket arrangement.
I would suggest a shim or two is required, from this listing it appears that MTC6154 is a shim as opposed to a nut plate - https://www.ebay.ch/itm/384158591930?hash=...SwZHNgmo74 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #956621 27th Jun 2022 8:03am
Bradders130
That’s great confirmation Shroppy, thanks. I think is off to the local Metal Supermaket then. £30.20 is crazy money for a shim! Shocked
Post #956622 27th Jun 2022 8:15am
That under body picture reminds me of how shoddy the paintwork was on defenders
Post #956791 29th Jun 2022 5:27am
Bradders130
Yep, I’ve just finished spraying the underside of the tub with Raptor. Looks good Very Happy
Post #956796 29th Jun 2022 8:02am
