Home > Camping, Caravanning and Holidays > HELP - iKamper X-Cover 2.0 onto Hannibal Rack
MattyEssex
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Indus Silver
So in panic mode currently, ordered new roof Tent Friday and planned first trip for this weekend coming.
Realised today that the bars on my Hannibal rack run the length of the car and not the width, having spoken to iKamper (who are brilliant) have been advised this will be an issue.
Tried to get Front Runner Slimline rack but delivery would be next week as coming from Germany.
Does anyone have any ideas on how to mount, I will be replacing rack.
My olnly hope is that it will attach to the cross rails but that is if they line up.
My Rack
iKamper Fitting
Post #955481 14th Jun 2022 4:04pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Clamp/ bolt 2 aluminium box sections perpendicular to your rails, then fit onto that? That’s what I’ve done on my old tent, means it’s a lot easier to get to the fittings too, otherwise that looks impossible!
Alex 98 300 tdi 90 project
88 200tdi project soft top
96 disco 1 jap import
79 911 sc
08 130 double cab utility
Post #955539 15th Jun 2022 7:47am
MattyEssex
Thanks Alex do you mean bars across, do you have a picture of yours at all? Thanks
Post #955566 15th Jun 2022 11:37am
landy andy
Add box to the cross members on yours so they are level with the surface and clamp those. The feet on the tent are adjustable. I also wouldn’t swap your rack. It’s one of the best out there and would be a step backward.
Post #955631 15th Jun 2022 8:24pm
MattyEssex
Thanks Andy when you say box what do you mean - I have been out tonight and bought these from Halfords with plan to mount across the rack but I like the idea of filling in so level with current rails.
Do you have any pictures? Thanks
Post #955632 15th Jun 2022 8:32pm
landy andy
Post #955638 15th Jun 2022 9:06pm
MattyEssex
Hopefully, have ordered those also, hoping they drop down to the cross bars …..
Post #955641 15th Jun 2022 9:17pm
landy andy
I see it as your length bars go where red box is. RTT clamps where blue box is, as they are now facing sideways.
Post #955643 15th Jun 2022 9:58pm
MattyEssex
So I’m thinking the red part in your pic clamps to the red circled area on my rack below and then as you say the RTT clamp goes onto the blue area in your picture.
Do you think that will give it enough to clamp onto?
Post #955644 15th Jun 2022 10:14pm
landy andy
If it is as you say then they are length ways, which I thought was an issue? The roof tents weigh very little and you are just holding it in place. In the end I had four bolts through the base of my tent, through the rack with a washer and nut. Lovely and simple, also couldn’t steal the tent unless you raised it first. Once you get the tent it will be easy to engineer a solution. The mounts on the tents move so it gives you options such as packing the bits you have just marked in your above pic, or making top hat sections that go between the longitudinal rungs
Post #955646 15th Jun 2022 10:43pm
chek
Switzerland 2016 Defender 90 Puma 2.2 SW Havana
How did it turn out in the end? I have a Skycamp Mini 2.0 on two Frontrunner bars on my 90, very happy with it.
Post #957561 7th Jul 2022 10:04am
camelman
Wouldn't you be better off with just roof bars? You can't actually use most of the rack once the tent is fitted anyway?
Post #957562 7th Jul 2022 10:12am
