![]() | Home > Maintenance & Modifications > Clutch pedal assist |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Yes they do. They can be a
https://www.defender2.net/forum/post782396.html#782396 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3784
For the full effect, go for the LOF clutch spring and master cylinder. The clutch is then light as a feather. Makes a huge difference and not an expensive job.
| Leamreject Member Since: 19 Dec 2020 Location: Middle Earth - Leamington Spa Posts: 970
I just had the LOF pedal spring fitted to my 2.4 Puma and found it made a big difference. Everyone’s experiences differ, but in my opinion having it to light just wouldn’t feel right.
My local Land Rover specialist supplied and fitted it FOC, but I do frequent them often Ride like you stole it!! If I’m not on a bike it’s because only a 4x4 will do… 2011 2.4 Puma 90 HT |
| steveww Member Since: 05 Jan 2022 Location: Malton Posts: 612
I have a 2.2 Puma and I don't find the clutch too heavy. However, one of previous owners may have already fitted the LOF spring. I've no idea how to check.
| htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 548
Have a look at the return spring, at the top of the pedal, if it light green its a LOF one, if its not its not.
| thomson_adam Member Since: 07 Dec 2021 Location: Cleveland Posts: 152 |
Have you done this ? Did you do it yourself ? |
I did. I think there is something about it in my build thread. Was a bit of a pig of a job as it’s fiddling and you need arms like Mr Tickle for one bit, but Luke at LOF was superb, more than happy to call me to give me some guidance on a Saturday afternoon.
https://www.defender2.net/forum/topic67542.html |
Found it. It starts half way down this page: https://www.defender2.net/forum/topic67542-180.html
I’ve ordered one , spoke to the chap from lof and he said get the spring first and see how you find it before changing the cylinder
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6052
I fitted spring (git of a job) then the slave cylinder. Too light, and too little feel for me. Swapped slave cylinder back to an OE part.
Fitted my Lof spring today
Was a right pain but got it done I’ve had to screw in my clutch stop bolt all the way , the clutch barely feels like it’s going to come back up. Anyone else experienced this ? |
I have contacted lof and they said my pedal may need raising
| Magoyo Member Since: 04 Feb 2022 Location: Buenos Aires Posts: 47
i just bought mine, it will arrive in 2 weeks. i will comment my exp after the instalation. Hope make a big difference ¡
Has anyone else had issues after fitting the spring ? Mine pauses at the bottom then returns
I hate adjusted the stop bolt at the back that didn’t make a difference , Luke suggest opening the master cylinder box and raising the pedal height. That’s made a slight difference but still not the best. I am tempted to put the original spring back In |
